Wierd Error after update (Resolved)
billyben_0077a25354
Had an update for Glute OCntrol Mechant resourc efor G8 pop up. I ran the update then opened DS 4.12. When I added g* female to a new scene I got the following error.
See attached file.
This happen to anyone else?
Post edited by billyben_0077a25354 on
You are probably better off asking in this commercial thread https://www.daz3d.com/forums/discussion/182076/glute-and-breast-control-genesis-8-commercial/p1 where the vendor is already posting about the update.
And yes, I am now getting that same error message.
There was an issue with update. Correction files have been set to Daz. Apologies for any inconvenience.
I too am having this issue (just started last night) so I am glad that someone brought it up.
Thank you.
The latest update seems to have cleared the 'duplicates' error. Thanks, Zev0!
And I'm using DIM, not Connect.
It's fixed, thanks Zevo
It is fixed for me also except for the current iteration of the model I was working on. Luckily I save often (usually between every major change or morph) and I was able to load a previous model and duplicate the changes I had made.
Thank you.
