Render issue with T Rex Berserker
Hello,
I have recently purchased the T. Rex Berserker model as well as several other dinosaur models by Herschell Hoffmeyer. I have been playing with them in DazStudio 4.12.0.86 using the default lighting and the Iray render engine. All of the models are using the supplied Iray materials and all render beautifully except for the T.Rex Berserker which renders completely white. I have tried reapplying the materails with the same results and I have looked at the surface settings but can't figure out why this is happening. Does anyone have any ideas as to what is going on with the renders?
Thanks in advance for any help.
nabob21
  • nabob21nabob21 Posts: 1,058
    As a comparison, here is a render showing both the T rex Berserker and T rex 3 models.
    1300 x 1000 - 300K
  • If you go to Help>Troubleshooting>View log after rendering and scroll to the end are there any errors relating to the materials or the render?
    Hi Richard,
    I am not exactly sure what I am looking for in the log but I can't see anything that says there is an error.
  • Please post the log.
    Here is the log file.
    txt
    txt
    log.txt
    23K
  • Have a look at the log after rendering oen of the figures that works - as I recall there are limits on the number of JIT compilations and lambdas that can be used (but that is from a way back), I'm wondering if the things that work have fewer of them.
    Thanks for your help with this Richard, but for some reason I am unable to attach a file to my post. It just says it is uploading but nothing happens so I will try to upload the log file a bit later.
  • FishtalesFishtales Posts: 6,228
    To my eyes it looks like too much light which is washing out the colours, why it isn't doing it to the other one though is a mystery. Check your light, environment light and tone mapping settings.
    Hello Fishtales,
    I am using the default lighting that comes with Daz Studio. It is only this particular model that is having the issue so I am not sure what is going on.
    I'm still not able to attach a file to my post. I keep getting a 522 error that says therre is somthing going on with the Daz site.
    edited November 2019
    We have reported the intermittent Clodflare errors that keep showing up    In the meantime just keep trying to attach your file.   If at first you don't succeed and all that
    Post edited by Chohole on
    Well after 4 days and several dozen tries I am still not able to attach a small log file to my post. I don't know what else anyone can do to help with my problem in the absence of that file but I do want to thank everyone that has tried to help.
    Post edited by nabob21 on
  • You could upload to Dropbox/OneDrive/Google Drive and post a link.
