reference screenshots, etc etc etc
MistaraMistara Posts: 38,675
edited July 2021 in Carrara Discussion
Adding Folders to Tray
i forget what goes where, so i made a ref
objects
shaders
Misc
To copy carrara browser tray to another pc, copy over the preferences.txt file
this the path to preference files
C:\Users\your windows10 user name\AppData\Roaming\DAZ 3D\Carrara 8.5
preferences.txt
sometime removing folder in the tray and re adding doesn't fix stuff, seen that sometimes a remnant remains in this rtext file
in that case go to the preferences.text and manually delete 4 lines related to the folder
sometimes a remnant is only 2 lines.
do a find for dazb  to zoom to any content folder remnant
Post edited by Mistara on
    other things i brain fart on
    HDRI goes under background
    light gels go under the light, effects, gel, map
    Sunbeams are under, realistic, sky, in the fog tab (2nd button)
    Rainbows are under sky  (not realistic sky)
    Camera depth of field previewer is under camers,effects
    Camera, minimum safe distance, like when red matter is dumped in a planet core,
    is under camera, general, distance to near plane, has a minimum of .01
    230 x 239 - 21K
    243 x 371 - 22K
    824 x 669 - 109K
    549 x 696 - 72K
    517 x 466 - 48K
    421 x 422 - 37K
    stuck in the hair decision making process, , which way to go?
    733 x 397 - 59K
  • ProPoseProPose Posts: 548
    Bookmarkedyes
    Reference of Modifiers  - the alpha channel tic box
    is the 2nd tab
    the Modifiers List -vertex
    261 x 521 - 44K
    257 x 306 - 28K
    257 x 356 - 29K
    249 x 284 - 26K
    251 x 282 - 26K
    254 x 324 - 31K
    233 x 321 - 29K
    edited July 2021
    Soft body  settings
    Scene Gravity
    235 x 546 - 40K
    257 x 542 - 40K
    245 x 308 - 28K
    Here is a playlist I made of the wonderful tutorials by JonStark on getting comfy with Carrara's dynamic hair. Wonderful advice!
    Jon Stark's Carrara Dynamic Hair Course
  • mindsongmindsong Posts: 1,788
    edited November 2019
    ProPose said:
    Bookmarkedyes
    yes yes
    yes yes
    Thanks Mystarra! (and other contributors...) this stuff is priceless when needed!
    --ms
    Post edited by mindsong on
    web dings and wing dings reference for text primitve
    the last 2 lines is split at N
    wingdings, wingdings2,wingdings3, webdings
    2000 x 937 - 431K
    Particle Emiiter presets
    Particle Emitter, Obj, Shader Domain
    1099 x 526 - 110K
    875 x 387 - 88K
    id you has the patience, follow along to where i gets stuck  dohh  lol
    preview shader options
    Color Picker Options
    Top Shader options Hair shader options
    Top Shader - Lighting model
    top shader  projection mapping  (overrides the uv map)
    Complex shaders
    global shader, Terrain options
    The terrain shader presets
    These tools I've ignored, cuz i don't know how to use em,  it draws on the preview ball
    Oval layer
    Polygon Layer,  rectangle layer
    I see here a layers dropdown for shader and opacity. ???
    but then what ???
    1143 x 498 - 161K
    329 x 407 - 23K
    716 x 218 - 75K
    720 x 257 - 79K
    649 x 424 - 65K
    1086 x 726 - 454K
    681 x 628 - 126K
    685 x 649 - 165K
    406 x 331 - 80K
    361 x 336 - 75K
    385 x 323 - 75K
    329 x 407 - 23K
    706 x 437 - 119K
    925 x 322 - 101K
    Bones Influence.
    rigging attempt  smiley
    so i was rigging the webding sickle moon and star.
    I anted bone 2 to move the star only.  but the points on the moon sickle were moving too
    used the bones influence tab, selected the pollies on the sickle, moved the bones influence sliders to make it 100% effected by bone 1.
    1052 x 490 - 76K
    Convert Text Primitive to Vertex
    On the edit menu
    quick uv map
    set all the text shader domains to 1
    select all the pollies first, then clickity add and rename as desired
    clickety del til all the xtra domains gone,
    739 x 559 - 147K
    661 x 618 - 72K
    648 x 640 - 84K
    DS screenshot,  Converting rigging
    Edit, Figure, Rigging, Concverrt ...
    906 x 578 - 264K
    Reference for new to Carrara - THE Production Frame
    thinking back to when i was new to Carrara, the first thing i got stuck on was the Production frame.
    Carrrara doesn't necessarily render the preview window.
    It renders what is Framed.
    Toggles production frame visibility
    To adjust the borders size of the frame
    If the production frame isn't letting you adjust the ratio,
    the Keep Proportions prolly needs to be toggled in render settings, output
    782 x 376 - 104K
    766 x 418 - 112K
    1105 x 363 - 57K
    Plain old Color+Gradient
    can hardly believe it
    the journy to find color gradient has reached the stattion, lol
    the shader dropdown has an option for 'gradient'  duhhh omg, going to sleep tonight with a smile  lol
    640 x 480 - 78K
    816 x 471 - 176K
    795 x 482 - 125K
    edited December 2019
    Gels SHadows+effects  shadow+gels  shadow+maps
    Carrara native light gels
    Barn Doors
    gradient shadow
    shadow map
    640 x 480 - 38K
    687 x 190 - 35K
    640 x 480 - 13K
    696 x 232 - 38K
    640 x 480 - 12K
    246 x 461 - 29K
