Export daz to .FBX (3ds Max 2018 and Maya 2018)
Hello! I want to export a scene that contains 18 genesis 3 characters to 3dsmax 2018. I'm not using face morphs, I only did body poses in every character.
The problem is that the file contains too much information for 3ds max (it crashes bc it uses 100% of the 16GB RAM). Is there any way to optimize that? Can I just keep the mesh of the bodies without the bones? (im not going to animate in 3dsmax).
Thank u!
If you are not going to animate you could try OBJ, using the option to prepend the node name to the group names to keep each easily selectable.
