How to make Genesis8 Female lips more natural
I found some of Genesis 8 female characters' lips are kind of strange. Like https://www.daz3d.com/clary-for-kanade-8
I think my lips are too thick and not natural.. Like the first two attached images. But the image in the product is like the third one...
So anyone can tell me how to make them more natural. Using any expression preset or shape preset? Thank you!
  • Bump removed
    How does the base Genesis 8 Female look? I think you have a character isntalled that has a non-zero deault value, so it always applies to the figure. If you look at the Currently Used group in the Parameters pane you shoudl be able to spot, and zero, the culprit.
  • Bump removed
    I checked the currently used group and found nothing... Just the Clary morph and Kanade morph. Like the attached image.
    655 x 677 - 255K
    716 x 629 - 261K
    472 x 126 - 16K
    1098 x 592 - 1M
  • Bump removed
    Base Genesis 8 Female look: see the attached files. I don't know if it's normal. But no other parameters were used. Thank you for your reply!
    867 x 686 - 303K
    771 x 682 - 262K
  • NathNath Posts: 3,006
    Looks like you already have something going on with the base g8f. This is what my g8f looks like.
    864 x 726 - 290K
    Thank you! I'll reinstall the content and have a try!
  • xueyt9518xueyt9518 Posts: 50
    edited November 2019
    Demona for Genesis 8 Female at Renderosity
    I found the problem. This head morph's default value is 100% and will be applied to every G8 characters...
    Please report that to the artists who made the product so that they can fix it. I've replaced the link with just the name, as it's from another store and the link isn't needed.
