Tape Measur
Hurdy3DHurdy3D Posts: 1,113
Is there anywhere a elastic rigged  measuring tape prop, that can be used the measure someones height or the range of the waste.
Searching something like this
Not talking about this product:
https://www.daz3d.com/measure-metrics-for-daz-studio
I want to render how someone is measuring himself.
  • Hurdy3DHurdy3D Posts: 1,113
    Kerya said:
    Thank you but it is for non commercial renders only
  • JOdelJOdel Posts: 6,322
    Also looks to be metric.
  • GordigGordig Posts: 10,839
    Range of the Waste is the name of my new punk band.
  • CybersoxCybersox Posts: 10,038
    Looks lhere's one inside this sewing kit by DivabugDesigns at renderosity https://www.renderosity.com/mod/bcs/sewing-notions/113612
    Note - I assume you mean flexible, not elastic, as the latter wouldn't exactly be accurate. :)  .
    hm thank you... but this tape looks like a static prop.
  • KeryaKerya Posts: 10,943
    gerster said:
    From the readme:
    This measuring tape can be used freely in renders.
    Roland59 at Renderosity, december 2009
    Unfortunately Rero doesn't have a "commercial renders allowed, no redistribution" license template ...
    but yes, it is centimeters:
    This figure is a measuring tape in centimeters used by tailors. The tape is
    1m50 long as usual.
    Sounds like the odds are that you'll probably end up having to kit bash something.  Of the top of my head, I see three fairly simple ways.  IN order of complexity -  -1.) take the folding wooden ruler in maclean's https://www.daz3d.com/everyday-tools , straighten it out to full length, then apply dforce on it to make it look like cloth.  2.)  take a poseable prop of approximately the right shape, like one of the dog leashes from https://www.daz3d.com/collars-and-leashes-for-daz-dogs-8 t, and add a ruller texture to it.  or 3.) use kaweki's strapmaker utility from Renderosity https://www.renderosity.com/mod/bcs/strap-maker/108024 to make a prop and then create a ruler texture.
    Kerya said:
    gerster said:
    From the readme:
    1m50 long as usual.
    oh nice... thank you for that info. I'll try that prop later and maybe I can replace the texture with an inch texture.
    hm... that tape crashes my studio frown
    2019-10-30 23:11:56.811 Importing File...
    2019-10-30 23:11:56.811 Importing Centimeter.cr2 ...
    2019-10-30 23:11:56.823 Reading Centimeter.obj
    2019-10-30 23:11:25.451 Error importing file: C Exception: Memory Access Violation - Attempted to read memory at address 0x00000024
    2019-10-30 23:11:25.451 File imported in: 0.1 sec (1370.28 ms)
    2019-10-30 23:11:25.499 Failed to import: D:/Workspace/My External Library/Runtime/libraries/Character/RS_Characters/Centimeter.cr2
    2019-10-30 23:11:25.499     Unhandled exception during operation
    2019-10-30 23:11:25.508 Building Scene...
    2019-10-30 23:12:01.662 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
    2019-10-30 23:11:43.765 Started in: C:/Program Files/DAZ 3D/DAZStudio4
    2019-10-30 23:11:43.765 DAZ Studio Started
    2019-10-30 23:11:43.765 Creating Pixel Buffer
    2019-10-30 23:11:43.807 Pixel buffer - Width: 1024 Height: 1024
    2019-10-30 23:11:43.807 Compiling OpenGL Shader...
    2019-10-30 23:11:43.819 Fragment Shader:
    If it has IK that may be a known bug in the general release with IK chains in some legacy figures - if so, it is fixed in the current Public Build (Beta).
    I don't think it has IK... it's an old power prop https://www.renderosity.com/mod/freestuff/measuring-tape/58624
  • I haven't tried opening it, but the CR2 does contain a custom IK chain definition so that could well be it.
    I'll add a fourth approach:
    Take one of the smooth ropes from Tied Up! 2 For Genesis 2 (or similar product). Select all the bones of the rope, but not the rope itself, and set their z scale to 1%. Create and apply a tape measure texture. I do this whenever I want to create a posable strap and it works fine.
