Adding to Cart…
Just to let everyone know... I have made a new autofit template specifically for Michael 4 Gloves that shows a vast improvement to the fit even without using a smoothing modifier. I would like to point out that the smoothing modifier still gives the best results because it forces the glove to fit the shape of the hand wearing it. The fit still causes some distortion in the original mesh, particularly in the fingertips of the ring and pinky fingers, but this is the best I have been able to come up with.
I also updated the autofit clone itself, reducing the amount of poke-through some have still experienced when not using a smoothing modifier. I was not able to solve the issue with capes and long coats. Unfortunately, because they follow the legs, there will almost always be issues with that when using autofit.
Lastly, I have updated the preset "Set M4 UVs" so that it does not set your shader back to DAZ default. I have submitted the updates to DAZ and hopefully they will be in your account shortly. When the update goes live, I will post here again so that those who do not use DIM can be notified to check your Product Library.
Thank you
I guess I should have included a picture, lol. Here is the glove from the Epsilon outfit for M4. Still not perfect, but much improved. Thank-you all for your patience and not immediately returning the product. That would have really bummed me out.
