Parameter settings On/Off How???
How do I get the "ON/OFF" button in the Parameter tab, instead of the parameter dials
  • You need to create a Boolean property - that's an option in the Add New Property dialogue.
  • MasterstrokeMasterstroke Posts: 2,367
    Found it, Thank you yes
    Is this only possible, when creating a new property, or is there a way to change an existing property into a boolean property?
  • I can't check just now, but I think the kind is fixed once the property is created.
