ready! - mcjShiftAnim - synthesize and modify existing animations
mCasualmCasual Posts: 4,607
edited December 2013 in Freebies
---------> manual and download
https://sites.google.com/site/mcasualsdazscripts3/mcjshiftanim
this script is very much like mcjCycleFilter
but doesn't have the graphical display ( and the associated sluggish response for long play-ranges )
it can modify the animation of any (float) property or morph channel for a given node
̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_
History
December 14th 2013 8 PM -
- fixed issue with the extremities of looping-time-shifted.
- implemented the ‘‘curPos’’ constant and the ‘‘pos’’ variable
December 13th 2013 - Released
example :
you found a dance animation but the dancer's feet are below ground level
with mcjShiftAnim select the figure's hip node
specify you want the YTrans parameter to be shifted 4 (centimeters ) up
the script will go through the entire play-range and apply this change
example, you have a dancing character, the arms are going up and down,
with the shoulders "bend" angle going from angle 20 degrees to 40 degrees
you could use mcjShiftAnim to keep the same movement, but raise the average arms height by
by adding 10 degrees to the bend angles
the script can also set a joint angle or a morph strength to its current-frame value or a value of your choice
and that's done for each frame of the play-range by the script !
there is also an expert mode wherein a programmer can type in a formula
example, i select the Bend angle of a shoulder
i type
val = 30 + 30 * sin( 5 * ang + pi / 2 );
and the arm will now gracefully bat at a rate of 5 cycles per play-range
the bend angles will range between 0 and 60 degrees
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    for important animation effects like
    - Anticipation
    - Follow through and overlapping action
    - Secondary action
    one often needs to shift a limb animation in time
    when building a walk or dance animation cycle we work on looping curves
    the last frame of the cycle must remain the same as the last one ... it's a loop
    so i added the ability to shift in time an animation curve without destroying the loop
    technically that's called a rotation
    there's will also be a function to shift without looping
    note that the mcjReTime script is better suited for cases where you want to time shift a whole pose-animation
    https://sites.google.com/site/mcasualsdazscripts2/mcjretimeanimation
    600 x 337 - 570K
    1370 x 566 - 62K
    same animation
    i repeated it 5 times using bLooper
    i added a sinewave motion to the YTrans of the hip node using the upcoming script
    i used mcjAutoLimb and mcjKeepOriend to "re-attach" the feet to the ground
    oops actually i replaced the vertical movement instead of adding it tp the original bouncy movement
    300 x 400 - 837K
    here the little shocks in the animation may be due to "aliasing"
    because of the low frame rate of 10 fps
    the vertical motion was created using the "expert" mode and a function like
    val = sin( ang * 1 ) * 12 + cos( ang * 2 ) * 6
    300 x 400 - 542K
    there !
    i removed the hard-knock movements from the hip rotations using mcjShiftAnim's simple 3-samples box filter
    oops ... error
    working on it
    well unfortunately i had to use good old mcjCycleFilter to filter/smoothen the animation curves
    but i'll fix the issue that caused the problem
    looks quite good though now
    figure 2 : the hip animation curves for this dance
    ( rendered using WebGL ! exported from daz using an upcoming-in-2014 script )
    ( meaning it's Mac compatible ny the way )
    470 x 749 - 54K
    300 x 400 - 544K
    i'll add a way to load save and reload the custom functions
    400 x 600 - 570K
    hula up
    added load/save function
    so if you created a formula like
    val = val +  ( cos( ang + pi / 2 )) * 5
    you can save it as fx_FlooredSine.txt
    and re-use it at a later date
    ( this formula was used to add some movement to the chest node's Bend channel
    and the side-side channel used
    val = val +  ( cos( ang  )) * 5
    since this is an additive effect ( val = val + ... ), i did not wipe out the important
    chest stabilizing work performed by mcjKeepOrient prior to this
    1920 x 917 - 202K
    600 x 319 - 771K
    skillz
    ( and resistance to cold )
    480 x 255 - 331K
    ready !
    and here you can see it also works in Daz Studio 1.8
    i developped it in Daz Studio 3
    still got to test it in DS4 !!! ... you never know
    ( i mean, I never know )
    600 x 776 - 497K
    so now the plan is, finish the Amywagen ( 1967 volkswagen transporter )
    then have the physics engine toy ready for xmas eve
    1600 x 900 - 672K
    * Update ** Update ** Update ** Update ** Update ** Update ** Update ** Update *
    - implemented the ''curPos'' constant and the ''pos'' variable
    the looping-time shift is very important for cycling animations, since it helps you tweak anticipation and follow-through
    in figure 2 i used mcjShiftAnim to animate the balls using the "Set" processing and the "Parameter"
    100*sin( ang )
    ( actually i used parameters locking and mcjParent to copy the first ball's Z motion )
    then i used mcjShiftAnim 's Looping-Time-Shift to delay the animation of the balls by, respectively, 5, 10, 15, 20, 25 frames
    600 x 337 - 166K
    842 x 792 - 48K
