Indentation on the forehead of my model??
ChameleonGalaxy
it was not visible on the daz ui but when i went to render she has a weird gouge in her forehead.
Update. it didn't eventually fill up.
How?
If you select the hair in the scene and then look on the "shaping" pane, there are probably adjustments. Note that I also sometimes see this when the figure is away from the (0,0,0) point - there's some kind of weird distance bug in iRay.
used blemish fixer in my pixler. ill try to co the skull cap thing if I figure it out...
