Indentation on the forehead of my model??
it was not visible on the daz ui but when i went to render she has a weird gouge in her forehead.
2880 x 1800 - 4M
  • Update. it didn't eventually fill up.
    2302 x 1274 - 1005K
  • FenixPhoenixFenixPhoenix Posts: 3,237
    That's caused by the skullcap of the hair. Try expanding/adjusting it so it doesn't collide with the forehead.
  • How?
    That's caused by the skullcap of the hair. Try expanding/adjusting it so it doesn't collide with the forehead.H
  • rames44rames44 Posts: 336
    If you select the hair in the scene and then look on the "shaping" pane, there are probably adjustments.  Note that I also sometimes see this when the figure is away from the (0,0,0) point - there's some kind of weird distance bug in iRay.
    How?
    As rames44 mentioned, most hairs come with adjustment morphs. Select the hair, and check the shaping or the parameters tab. There should be a list of adjustments (usually under Actors).
  • used blemish fixer in my pixler. ill try to co the skull cap thing if I figure it out...
