Michael and Victoria 6 HD Add-ons Now Availalbe
1235»
  • RogerbeeRogerbee Posts: 4,460
    edited December 2013
    Jabba101 said:
    I normally use "alt shading rate" for hair instead of primitive hitmode, upping quality just enough to get rid of any noise.
    Sounds good, just how do you do that?
    CHEERS!
    Post edited by Rogerbee on
  • JabbaJabba Posts: 1,461
    It's part of the Advanced light flagging options, but I don't want to go off topic (or at least feel I better not go too far off topic), so I'll link to my livestream vid...
    http://youtu.be/OgDmM-YFPmY?t=8m1s
    hope that helps ;-)
    Post edited by Jabba on
    Oh, yeah, sure, I'll find it. Thanks for that.
    CHEERS!
    Here is a scene I did with M6,
    I made it before I had the HD morphs and then added them when I bought them. The texture is the M5 Elite Dave texture with Add Some Veins added.
    If you check between the two renders you will see the difference between HD and non HD
    CHEERS!
    576 x 745 - 229K
    576 x 745 - 229K
  • Sal UKSal UK Posts: 432
    I must be blinder than I thought I cant see the difference?
    I been having a mess again though I prefer the earlier renders I did, thought I would post it as the HD details look good.
    1471 x 2000 - 892K
    Yeah, I wasn't convinced either, till I looked at them via Windows Photo Viewer and flicked between the two. Everything in the HD render is much more defined and there are changes across the whole figure. This was why I was initially unenamoured with M6HD as everything appeared to be too subtle.
    That character morph you've done is beautiful, you should give her a name and release her
    CHEERS!
    Thanks again Rogerbee
    Ill go into studio later and save off a scene with just V6HD with the dialed morphs on the face, and put the default clothes on her and add the duf file to my gallery if that feature is working, Ill add it to all 3 in the portraits folder as I used it in all 3.
    steve.
    Post edited by Sal UK on
    Cool,
    I'm not sure how you save dialable morphs with Genesis yet.
    CHEERS!
    I was initially unenamoured of the Bjorn texture, then I played with the shader settings, did a little morph dialling and I really like him now.
    CHEERS!
    576 x 745 - 285K
  • VanguardVanguard Posts: 505
    Lovin' the HD
    This is Victoria 6HD pretty much straight out of the box morph and texture wise.
    She simply screams screen siren to me :P
    783 x 1021 - 352K
    Now that is a great render,
    I wouldn't mind knowing how that was lit.
    CHEERS!
    CHEERS!
    Thanks Roger.
    I added the scene file to the gallery listing.
    http://www.daz3d.com/gallery/images/17493/
    I don't know how well it works if you don't have all the items in the scene, but if you have V6HD you will at least get that and the lights are standard spots.
    The way I work lights is to position the perspective view where I think a light should be and then add a light using the Create menu, add light and have it copy the active view-port. Then I adjust settings.
    You will see that there is no background in the scene. I used the background as a transparent alpha channel ad added it in Photoshop. Nothing magic, just a simple thing.
    Post edited by Vanguard on
    When you click the 'Download Scene File' button, all that happens is that you get taken to the main gallery. Not sure what happened there.
    CHEERS!
  • LindseyLindsey Posts: 2,012
    In Windows, I was able to download it by selecting the link, right click and select "Save Target as.." which opens a file save window.
    edit: @Vanguard, thanks for sharing your Siren HD scene file!
    Post edited by Lindsey on
    Must have been IE, I did it in Waterfox by doing 'Open link in new tab'.
    I got it anyway
    CHEERS!
