Right file location fpr Mod D.R.
I am attempting to set up this this dressing room set, but I noticed that the extracted files do not appear the way I expected them to.
...and sure enough, they didn't load.  (screenshots)
In fact, the extracted files deemed to have appeared seperately, as they did when I downloaded them.
...only in the filed I merged them into, to set up a path, to open them in Daz.
I'm guessing that perhaps the extracted files need to be copied and merged in the correct folder.
Is that correct?
What folder would I place them in?
  • NorthOf45NorthOf45 Posts: 5,814
    Third-party products must be extracted into the proper folders to be functional in DAZ Studio. Look in the folders an you will see folder names that match those set up under DAZ Studio Format in your content library (data, Documentation, Environments, Runtime). You must extract to the same folders to get everything to work properly.
  • dash2128dash2128 Posts: 736
    Yep, that did it!
    Thanks!
    I merged the 3 files into one, following your advice.
    Thank You!!!!!!!
