Problem with no content to download in DIM
2»
  • memcneil70memcneil70 Posts: 5,447
    I had problems before the update. But installed .51 update and all downloads went fast and smooth.
  • NovicaNovica Posts: 23,925
    I just happened to be doing other things so when clicking that, it's only version .51 so yeah, I'll wait and watch for the .52
  • Apparewntly .52 is delayed. The chnage was allowing + in the log-in details, which .51 doesn't, so if you have trouble signing in and if your details (email or password) have a + the workaround would be to go to the website and temporarily chnage the details until the new update is released.
  • L'AdairL'Adair Posts: 9,479
    edited October 2019
    Novica said:
    Well, my DIM was closed so when I opened it just now, it says there's an update. Is that the fix for whatever they did to make it screwy, or is this update the screwy?   I'm not sure I want to install this, whatever it is.
    There is about to be another update, I'm told, so you maty want to wait (assuming you are not already up to 1.2.0.52)
    Interesting. I'm still using 1.2.0.27. DIM has always required I update in the past, so I'm surprised there are later versions!
    Regardless, I was also having issues the same as others reported, even with .27. (FWIW)
    ETA: Nevermined. I just checked the sticky and see the update was released earlier today…!
    Post edited by L'Adair on
  • TaozTaoz Posts: 10,281
    I just updated (after the problems), working fine here.
