GenX2 and V4 foot pose
Is there any way to reset the V4.2 morph in GenX2 so that the foot pose looks more like G3?
Whenever I create morphs from GenX2 using V4.2, the feet are always on tippy-toes which messes with poses. I've tried recreating the V4.2 source morph in GenX2 so that  the feet are flat but I haven't had much luck fixing it.
Thanks!
  • SixDsSixDs Posts: 2,384
    Open the V4 base and set the feet to the flat-on the-floor position. Now with V4 selected, create a new .cr2 file (File > Export > Poser CR2 File). Give it a new name to avoid overwriting the original base V4 .cr2. That should work.
  • evacynevacyn Posts: 993
    Thanks. I've managed to export the V4 cr2 with the flat foot pose, but GenX2 still uses the original Victoria 4.2 source which has the tippy toe pose. How do I replace the Victoria 4.2 morph that GenX2 moprh with the new flat foot V4.2 I created?
    Okay - I've found how to remove the V4 morph and I've created a new one based on the flat foot pose cr2 V4 I made, but when I apply it in the Generation X morphs (on the Parameters tab) it still goes back to the tippy toe pose. It seems to ignore any pose I apply to the V4 that I save as a cr2.
