Rex comes with Anagenesis materials - what does this mean?
HylasHylas Posts: 5,349
I've snatched Rex while he's in Fast Grab. I see that he comes with 3Delight materials, IRAY materials, and Anagenesis materials. What does latter mean?
  • Matt_CastleMatt_Castle Posts: 3,309
    Specialised Iray shader parameters - check out the Dimenson-Z Store for more details:
    https://www.daz3d.com/dimension-z
  • CybersoxCybersox Posts: 10,038
    Good question.  It obviously means that those presets were created using Dimension-Z's anagenesis shaders, but whether it's Anagenesis 1 or 2, and whether it requires the original product to use them or not is a bit of a mystery.
  • HylasHylas Posts: 5,349
    Sorry Matt, I still don't understand...
    Are those materials created using Anagenesis, or are they created to be used with Anagenesis?
    I did an IRAY test render using the Anagenesis materials (I don't own either Anagenesis product) and the result looks better than the non-Anagenesis IRAY materials. Which makes me wonder, why even include the non-Anagenesis IRAY materials?
    Of course I'll ultimately just go with what looks best to me... but I'm still curious how the materials are meant to be used.
  • nicsttnicstt Posts: 11,715
    They should be stand-alone; just use the character.
  • nemesis10nemesis10 Posts: 4,056
    They have the Anagenesis 2 shaders are ready to render out of the box... There are a few other products that include the Anagenesis 2 merchant resources such as https://www.daz3d.com/lie-tattoo-presets-2-for-genesis-3-and-8-male/
    ^ "LIE tattoo presets 2" sais it requires Anagenessis to work though...
  • SevrinSevrin Posts: 6,314
    N.G.S. Anagenessis for Genesis 3 required for use with N.G.S. Anagenessis Presets
    If you're using the tattoos on that character, using Anagenessis presets then yes.  If you're using the Iray presets, then no.
    In particular, if you have a character with the Anagenesis 2 settings, use the Anagenesis 2 tattoo, and if not, use the regular tattoo...  If you have been follwing Dimension-Z's DeviantArt page, Anagenesis 3 is going to be epic!
  • ArtiniArtini Posts: 11,036
    edited October 2019
    Have just looked at the https://www.daz3d.com/rex-for-genesis-8-male - and just wondered.
    Where did you see mention about Anagenesis?
    1209 x 1275 - 349K
    Post edited by Artini on
    Besides having the product, note Additional Details and look at the file list: http://docs.daz3d.com/doku.php/public/read_me/index/57045/start/
  • TykeyStudiosTykeyStudios Posts: 892
    edited October 2019
    Gypsyangel has included NGS options for most, if not all of her  newer G3 as well as her G8 characters. At least all her G3-G8 men I have purchased have the option since the release of Anagenessis. It does not say it in the description but Rex definitely comes with the options. I understood it that Hylas saw the options inside DS.
    Post edited by TykeyStudios on
    Ok, thanks, and good to know.
    So L'Adair tells me over in a different thread that Anagenessis is a merchant resource. So I guess Rex' Anagenessis options were created using Anagenessis but can be used without that product.
    I kinda wonder why the standard IRAY materials were even included since the Anagenessis materials look significantly better.
    As a huge fan of the Anagenesis products, I also think they make skin look better (as do some other products in the store) but it is an aesthetic choice so others may disagree much like that Iraq/3delight divide.
    As a huge fan of the Anagenesis products, I also think they make skin look better (as do some other products in the store) but it is an aesthetic choice so others may disagree vis
  • vwranglervwrangler Posts: 5,060
    I realize that's just a typo and it's probably more a mark of how weird my mind can be sometimes, but I spent a good few seconds trying to figure out if there was some geopolitical objection to 3Delight that Iraq had expressed.
    For what it's worth, I kind of prefer the Iray materials not so much because they're better or worse than Anagenessis, but because the general Iray shaders can be more flexible -- adding tattoos without screwing up the shader model, or what have you -- because not that many vendors actually produced Anagenessis materials for their characters. I think it may have just been Darwins Mishap and Gypsyangel.
    I didn't notice that!
    vwrangler said:
    nemesis10 said:
    Hylas said:
    laughSo L'Adair tells me over in a different thread that Anagenessis is a merchant resource. So I guess Rex' Anagenessis options were created using Anagenessis but can be used without that product.
    I literally lol-ed when I read that! With all the crazy politics going on now, I burst into laughter thinking that now Iraq and 3Delight were divided! Hope it doesn’t get banned because of 3Delight politics lol wink laugh
