Realistic Renders.....NOT!! 13: A new room to fill!
Adding to Cart…
It would be interesting to see the render with out the HD add on to compare and see if there is truly a noticeable difference, or if it's a bunch of hype.
Thank you, I already deleted the non HD version, lol. Well basicly, yes it is visible, I'll post another render with more HD add on area focused and comparison between 2 images.
1st image with HD add on
2nd image no HD add on
1st image with HD Add on
2nd image no HD Add on
:red: thanks that means a lot :D
A bit off topic but i thought i'd just say that I owe alot to these forums the people on them and especially this thread through the years.
I learned a lot from jamminwolfie when i first wandered into the daz forums and from various people that stopped by.
and i am glad that Rogerbee is keeping it going.
It's to bad there isn't a "like button to tag pics lol I suck at commenting here but i love seeing all the stuff posted and that would come in handy.
oh since I'm here might as well post my first render using the AAL
I think so,
I never use any standard lights. You do look to have missed out her lower legs though. In DS4.6 there's a parameter in Surfaces where you can just select the skin, do you have that!? If not, just make sure you select all of her skin and it should be fine.
CHEERS!
Looks great,
And no, you're not spamming, LOL!
CHEERS!
That looks brilliant,
Definitely the kind of thing I'd look to be doing myself.
CHEERS!
Nice HD renders,
You do wonder though if a decent displacement map could do the job just as well...
CHEERS!
Nice work,
I'm going to try a couple of mine again but with a different light set.
CHEERS!
Nice HD renders,
CHEERS!Yes, it can all be done with displacement maps... the advantage with HD morphs is that you're not restricted to a single UV, so can throw on any V6, V5, V4, Gia texture if it suits your character better.
But yeah, the HD does take longer to render.
In addition of what Jabba said, the other advantage of using sculpted morph like HD add on is, you could use the displacement maps for other skin overlay ^^ which will give you more option.
Well render time worths its quality, guess I need to get used to that from now on when rendering with HD add on.
Those were very informative, and very nice renders as well. I liked the added geometry of the lips and ears visible in your portrait render, but I actually preferred the non-HD render of the full body for some reason. Maybe I'm to used to V4. ;-)
Interesting,
I'll have to see what I can do when I get them this week, I do hope they're not back up to full price by then.
Other lights, Lantios being the main sets I have, didn't really make much difference so I stuck with what I've been using. I realised that the Cassie freebie was a full character so I decided to render her, Re-interjection didn't work on her skin so I just used the eyes. I also decided to render M6 (M6's texture is great straight out of the box so he doesn't need any additional work.) and discovered that M6/G2M and V6/G2F share eye UV's so I was able to use the G2F presets from Re-interjection on his eyes. Something which I'll mention to Dimension Theory as he now doesn't need to make another Project EYEris for G2M as anything from the G2F version he's just released will work anyway.
CHEERS!
I just asked for help in another thread. Maybe an experience moderator might have some ideas as to what I am doing wrong with reinterject. The stockings are from the mad nurse outfit. I know, who wears stockings with a granite bikini? lol
A stone cold bitch. :-)
I don't actually know if you are doing anything wrong. If you're expecting results like mine you do have to bear in mind that I'm using different lights and possibly render settings.
CHEERS!
Let me try Andrea's IBL light or the Yosemite HDRI to see what happens. ahh.. I'm in the middle of another render. I'll get back to you.
Nah, maybe it's because I don't use the additional Gen2 morph, so the full body morph looks kinda weird or like a doll. I'm starting to like G2 more and more compare to V4 despite the long render time with HD add on. One thing I don't like with Genesis, the products for them are way too pricey.
Btw, anyone familiar with AoA SSS ? Is it just me or if we use AoA SSS when rendering, the render will halted like 5-10 minutes when trying to render skin, then it will render afterward. Is it somekind of pre-rendering the SSS ? I don't have problem like this with USS
I have similar issues with the EHSS and reinterject in Daz Studio 4 but the renderer stops at the top of people's hair. Transmap hair, sub surface scattering and regular lights cause the renderers to slow down. Sorry I couldn't help out more. Somebody else should have a better explanation.
edit: forgot something
I am so loving the Visual Styles shader. It really makes for nice low poly render.
Nice, I haven't seen graphics like that for 20 years!
CHEERS!
Yayy!!
I can mix and match! I put Axel's texture on M6 and used the eye texture from Axel, BUT, I was able to use the G2F preset from Reinterjection which used the eye surface, nice!
BTW, you might see this guy again, but on America's Most Wanted!
CHEERS!
I think in the case of M6/V6 HD there is considerable hype-factor. The biggest disappointment is that there are only two sliders: head and body. I hate what it does to M6 legs, but I have no way I know of to apply HD to part of the body and not other parts. I think the price is too high for what you get. I do think HD will prove valuable in other products. I have great hope for Zev0's aging morphs when they are released.
Yes, it is working as designed. AoA describes the delay for the precalculations in the shader documentation, I think. My renders always stop for several minutes when it reaches the surface with the AoA SSS shader. Then they resume and render at normal speed.
I'll shamelessly cross-post this in here too - my first render using RawArt's Wither HD
Rendered in DS 4.6
Life Plus 10...
Intruder Alert!
Rendered with UE2 with high settings. Took forever to render the hair. One of these days I'll try the new Ambient lighting products.
Next step is to learn how to add motion effects.
Very nice. Love how those metal bars look.
Low Poly is like the Instagram of the 3D world.
I see, glad that it isn't just me with the AoA SSS. I tought it was my setting gone wrong somewhere ^^.
HD add-on is great product yes, but as you've mentioned sadly it only have 2 slider that is the big dissapointment I couldn't agree more. I hope that DAZ will make them per part body dial parameter so we could make our OC unique each creation with HD Add-on.
But I was lucky enough I got the HD Add-on with 30% discount. (That is the reasonable price to my opinion 27.96 USD with only 2 dial morph)
