woah, keyframe diffuse color change, a way to save animated shader??
Mistara
Mistara
You can keyframe almost everything in the shader tabs
including glow channel colour and intensity if using an operator
and use image series
in displacement even
its probably my most used feature in animation as works in other render engines too like Octane
kewl, wanna see if can save as a pose. fighting fatigue atmo. ate too many nutter butters.
I have saved various animated shaders and could use an NLA clip not a pose as such
might be able to notepad hack a single frame. mebbe
I am lost
you want to save a shader you just save a shader
if you don't want it animated you remove the keyframes
dunno why or how you would save a pose for a shader
but if you wanted to change the animation to one you could do an NLA clip for it but it would be for just that shader
huh rosty gallery won't play animated gif
can't post test anywhere
would save a pose for a shader if it won't overright the loaded texture map
4 years later NLA still mysterious.
image series on a prop is the real fun stuff.
scifi funk made a tutorial on it. avi on a blimp.
his tutts are down, rummaging thru old flash drives for it.
Avi gives me nothing but grief in Carrara.
why I use image series
you seem to see no issues maybe you have better codec packages with your expensive video editing softwares
I render stills, paste 'em together in Pinnacle.
i using the SONY software. until i can get my mini mac
image series, you go to every frame to upload an image in shader room?
or you upload the whole sequence at once?
At once
when you open an image you can choose sequence
that sounds more realistic.
i have a personal rule of 10 seconds. if is 300 frames or less i render uncompressed avi.
i didn't put money into gpu, went for the ocatcore. octane does look nice tho
don't need a great GPU if not using a GPU based renderer
it just worked out cheaper for me to settle for less CPU and the price of Octane with a decent card
I actually love Carrara native engine but would need a multi Xeon render farm to get the times
nm
beginning to feel christmas, carrara animated shader.
started a site folder for Carrara3dX
about to try shader on other pc ... aww it added frames, but not the key frames, applied omly the first red frame
tha nla tab doesnt show when i select clor track or the object
a lil bummed it didnt work. on other pc was abl to apply it to 2nd object in same scene
when i save the cube to tray, animated shader saves with it.
so i guess one workflow would be to load in the cube to bring the shader in
The shader itself should save too, drag the ball into the browser
it only saved the first frame. on my pc
i don't understand why the nla tab doesn't appear
hopefully these brain teasers are protecting me from alzheimers
NLA you need an animation group
odd the shader didn't save with keyframes
tried grouping the shader track with the cube to make animation group. group is grayed out
woulda thought anything with keyframes would activate the nla tab.
mebbe a 2nd shot of jamieson will revv it up
i want it to do more than change colors
want shimmering with noise speckes and turbulence
As far as I know (...which isn't very far...) animated shaders can't be part of an NLA track, despite evidence they *possibly* can be. I started a thread a while ago, but I think the concept is a dead end, or was never fully implemented.
(Pure speculation on that last part...)
https://www.daz3d.com/forums/discussion/339011/animate-shader-in-an-nla-clip#latest
Cheers all
forgotten what I have tried with my music visualization that worked or didn't
I just managed to give Carrara a Nil pointer error playing with Veloute and Shoestring shaders animated though
Wendy, you're Nikola Tesla level genius
was hoping to save only selected channels in the shader
The high tension powerlines I follow to the shops are sizzling in the rain, I was imagining Tesla coils sparking and crackling
so far, the only thing works is to set the shader on an object. save the obj,
bring obj into fresh scene to bring in the shader, then apply the shader to obj desired
tried again to save as shader, only saves the first frame
and i just noticed, lol, selecting shader in bottom shader tab, shows all the instances the shader is used on
attached is the primitive, if anyone wants to test bringing it into scene for the animated shader.
(not really zipped, manually typed zip extenstion)
