woah, keyframe diffuse color change, a way to save animated shader??
MistaraMistara Posts: 38,675
edited October 2019 in Carrara Discussion
woah no one told me  cans keyframe a colo(u)r change in diffuse channel.
this solves so many problems
so i guess next question, can save blinking colors in nla clip
or can save a pose of every channelcept the texture map
903 x 631 - 102K
Post edited by Mistara on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    edited October 2019
    You can keyframe almost everything in the shader tabs
    including glow channel colour and intensity if using an operator
    and use image series
    in displacement even
    its probably my most used feature in animation as works in other render engines too like Octane
    kewl,  wanna see if can save as a pose.  fighting fatigue atmo.  ate too many nutter butters.
    I have saved various animated shaders and could use an NLA clip not a pose as such
    might be able to notepad hack a single frame. mebbe
    I am lost cheeky
    you want to save a shader you just save a shader
    if you don't want it animated you remove the keyframes
    dunno why or how you would save a pose for a shader
    but if you wanted to change the animation to one you could do an NLA clip for it but it would be for just that shader
    huh rosty gallery won't play animated gif
    can't post test anywhere
    I am lost cheeky
    would save a pose for a shader if it won't overright the loaded texture map
    4 years later  NLA still mysterious.
    image series on a prop  is the real fun stuff.
    scifi funk made a tutorial on it. avi on a blimp.
    his tutts are down, rummaging thru old flash drives for it.
    Avi gives me nothing but grief in Carrara.
    why I use image series
    you seem to see no issues maybe you have better codec packages with your expensive video editing softwares
  • I render stills, paste 'em together in Pinnacle.
    i using the SONY software.  until i can get my mini mac
    image series, you go to every frame to upload an image in shader room?
    or you upload the whole sequence at once?
    At once
    when you open an image you can choose sequence
    At once
    that sounds more realistic. smiley
    i have a personal rule of 10 seconds.  if is 300 frames or less i render uncompressed avi.
    i didn't put money into gpu, went for the ocatcore. octane does look nice tho
    edited October 2019
    don't need a great GPU if not using a GPU based renderer
    it just worked out cheaper for me to settle for less CPU and  the price of Octane with a decent card
    I actually love Carrara native engine but would need a multi Xeon render farm to get the times
    edited October 2019
    nm
    edited October 2019
    beginning to feel christmas,  carrara animated shader.
    started a site folder for Carrara3dX
    about to try shader on other pc   ...  aww it added frames, but not the key frames, applied omly the first red frame
    tha nla tab doesnt show when i select clor track or the object
    a lil bummed it didnt work.  on other pc was abl to apply it to 2nd object in same scene
    1407 x 677 - 125K
    when i save the cube to tray, animated shader saves with it.
    so i guess one workflow would be to load in the cube to bring the shader in
    The shader itself should save too, drag the ball into the browser
    it only saved the first frame.  on my pc
    i don't understand why the nla tab doesn't appear
    hopefully these brain teasers are protecting me from alzheimers
    edited October 2019
    NLA you need an animation group
    odd the shader didn't save with keyframes
    tried grouping the shader track with the cube to make animation group.  group is grayed out
    woulda thought anything with keyframes would activate the nla tab.
    mebbe a 2nd shot of jamieson will revv it up
    i want it to do more than change colors
    want shimmering with noise speckes and turbulence
  • DesertDudeDesertDude Posts: 1,239
    As far as I know (...which isn't very far...) animated shaders can't be part of an NLA track, despite evidence they *possibly* can be. I started a thread a while ago, but I think the concept is a dead end, or was never fully implemented.
    (Pure speculation on that last part...)
    https://www.daz3d.com/forums/discussion/339011/animate-shader-in-an-nla-clip#latest
    Cheers all
    edited October 2019
    forgotten what I have tried with my music visualization that worked or didn't
    I just managed to give Carrara a Nil pointer error playing with Veloute and Shoestring shaders animated though
    Wendy, you're Nikola Tesla level genius heart
    was hoping to save only selected channels in the shader
    The high tension powerlines I follow to the shops are sizzling in the rain, I was imagining Tesla coils sparking and crackling
    so far, the only thing works is to set the shader on an object. save the obj,
    bring obj into fresh scene to bring in the shader, then apply the shader to obj desired
    tried again to save as shader, only saves the first frame
    and i just noticed, lol, selecting shader in bottom shader tab, shows all the instances the shader is used on
    attached is the primitive, if anyone wants to test bringing it into scene for the animated shader.
    (not really zipped, manually typed zip extenstion)
    zip
    zip
    Animated Shader text Cube.car.zip
    5K
    1087 x 605 - 112K
