Ready ! -- mcjSetRotationAxis - script to set the rotation axis of props and objects
mCasualmCasual Posts: 4,607
edited December 2013 in Freebies
Ready !
manual and download here
------------> https://sites.google.com/site/mcasualsdazscripts3/mcjchangeorientation
as you could see in the movie "it's tilted, babies" ( https://www.youtube.com/watch?v=GDGXSmuEr0U )
sometimes you need a hinge rotation axis that is not vertical and not horizontal
for car doors notably
it could possibly be useful when building low poly prop-figures ( stickman )
i'll see if i can also make it helpful for steerable car wheels
Agent Amy Hanging out near the ice merchandiser
( includes tilted hinges, babies )
Post edited by mCasual on
  • edited December 1969
    That's a great idea! In the past, to make Steering Wheels, I had to parent it to a Null for the rotation!
  • mCasualmCasual Posts: 4,607
    that time when agent Amy kept opening and closing the ice merchandiser's tilted hinged door
    500 x 281 - 780K
    gotta finish this tilted-hinges script,
    then the plan is to quickly wrap up the Amywagen ( volkswagen pickup )
    then have the physics simulation thing ready for xmas, so people have something to play with at 4 am on Dec 25
    1600 x 1200 - 401K
    1600 x 900 - 292K
    in case a programmer ever wants to do something similar
    the source code to change the orientation ( y axis ) of a node ( door )
    based on the vector formed by two nodes
    as a bonus the node having its orientation changed
    does not need to have its transforms zeroed
    var n0 = Scene.getSelectedNode( 0 );
    var n1 = Scene.getSelectedNode( 1 );
    var door = Scene.getSelectedNode( 2 );
    var up = DzVec3( 0, 1, 0 );
    // according to a famous technical director
    // the most important thing to remember
    // is that you cant apply a transform to a vector
    // the same way you apply it to a position
    // so i apply the transform to the positions
    // of the extremities of my segment
    // then i get my vector transformed
    // from the transformed extremity positions
    var n0p = n0.getWSPos();
    var n1p = n1.getWSPos();
    var trans = door.getWSTransform();
    trans = trans.inverse();
    n0p = trans.multMatrixVec( n0p );
    n1p = trans.multMatrixVec( n1p );
    v = n1p.subtract( n0p );
    r = v.getRotationTo( up );
    beginUndo();
    door.setOrientation( r, true );
    acceptUndo( "changeOrientation" );
    and this code snippet is used to change the location of the node's origin
    var p0 = n0.getWSPos();
    //bring p0 in the door's local space
    p0 = trans.multMatrixVec( p0 )
    var o = door.getOrigin()
    //because positions are relative to the current origin
    p0 = p0.add( o );
    beginUndo();
    door.setOrigin( p0 );
    acceptUndo( "changeOrigin" );
    for the test case the subject ( door ) was moved away from its load-time position and was rotated 45 degrees
    1188 x 699 - 94K
    The User Interface in DS3
    and the steering for upcoming tests
    new improved fidelity steering for the Amywagen
    ( the reference being 1967 bus / pickups
    on some VW items there's the coat of arms of the city of Wolfsburg - a two-tower castle over which paces a golden wolf with a blue tongue.
    1600 x 1200 - 179K
    1600 x 1200 - 349K
    459 x 269 - 26K
    when you use a primitives/cylinder as a tire
    the x y z axis don't allow you to have the wheel roll and remain steerable
    but using this script you'll be able to reorient the Y A xis
    and get the roll & steer without having to use nulls
    a sad thing is that yesterday was it, i had almost completed the script when Daz Studio crashed on me
    and apparently i never saved this version !
    the silver lining is that it's much faster to re-write it than it was to write it
    880 x 508 - 51K
    878 x 514 - 37K
    480 x 270 - 201K
    oh my i was almost forgetting i have to do finish this script before resuming work on the Amywagen, then get back to the physics toy
    new mirror !
    which incidentally may require use of mcjSetRotationAxis for the rigging
    1280 x 720 - 460K
    1280 x 720 - 131K
    Someday soon i'll publish a new version of mcjAutolimb ( an indispensable DS animation tool if i can say so myself )
    with auto-spin !
    but for now today i'll complete mcjSetRotationAxis
    480 x 480 - 762K
    complex test case for the axis re-orienter script
    the Amywagen mirror
    1920 x 1200 - 286K
    it worked well but only when thee 3 elements of the mirror assembly were in an unrotated state to start with
    so i have to re-discover the code that i used for the Ice Merchandiser door test
    600 x 600 - 631K
    1906 x 795 - 1M
  • RAMWolffRAMWolff Posts: 10,363
    WOW, this is going to be useful!
    hoping to post it today
    then on to the Amywagen
    600 x 337 - 238K
    1920 x 1200 - 66K
    I'm getting dizzy watching Aiko!
    so this script can re-orient an object's Y axis anyway you like
    but the 2 other axis of the "rotation frame" can not be left to chance
    so i will add the "then orient the X Axis according to" options
    it will spin the rotation frame about the new Y Axis
    920 x 522 - 98K
    Looks cool.
    By the way, have you ever written a script that would reposition a prop's world rotation? You know sometimes when you load a prop and then try to move it around the rotation seems really off, like the prop fly's away from the position it was previously in? I've always hated when that would happen, esp in 3D space, you just don't know sometimes where the hell it went! lol Might be useful!
    adding all those options gets a bit confusing
    but it may let you rig a custom prop just the way you want
    in this case the Y Rotation Axis ( green circle ) of the object was re-aligned along the World's X axis ( red arrow )
    and the X Rotation Axis ( red circle ) of the object was re-aligned along the World's Z axis ( blue arrow )
    1300 x 748 - 166K
    WOW cool beans, so this script may do what I was asking too?
    see in the user interface of the upcoming script there's a button labeled "Set Origin To Marker 1"
    this means you could position and select a null node, then select the prop,
    and the script would place the prop's origin at the location of the null
    for years what i've been using for this task is the MoveOrigin script by DeltaX15
    http://www.4shared.com/dir/722776/10801f63/DS_Scripts.html
    but i also saw that Daz Studio 4 has new sub-menus where you can change a node's origin
    https://www.google.ca/search?q=moveorigin+script+daz&oq=moveorigin+script+daz
    also shown in the image below, rotating the rotation frame 45 degrees using the "angle" slider
    1413 x 787 - 156K
    the finishing touch, i added the "three markers" mode
    the line going from the first selected marker to the second gives the prop's new Y-Rotation axis
    and the line going from the first selected marker to the third gives the prop's new X-Rotation axis
    ( the script forces the second vector to be perpendicular to the other )
    1413 x 787 - 167K
    Looking forward to this release.
    Is the VW still in production?
    new improved code to change the origin of an object, but without disturbing its position
    var marker0 = Scene.getSelectedNode( 0 );
    var door = Scene.getSelectedNode( 1 );
    var p0 = marker0.getWSPos();
    var itrans = trans.inverse();
    p0 = itrans.multMatrixVec( p0 )
    o = o.add( p0 );
    beginUndo();
    door.setOrigin( o );
    door.setWSPos( marker0.getWSPos() )
    image below for decorative purposes
    1416 x 792 - 119K
    that's what i was calling the Amywagen
    once i'm done with this script ( today for sure! ) i get back to the Amywagen
    and the hope is, this will be followed by an improved version of the physics simulation kit, in time for Dec. 24
    old unrelated pic for decorative purposes
    640 x 480 - 63K
    Oh my!
    it's done and i can return to modeling the Amywagen ( 1967 Volkswagen Transporter )
    i did a few tests of the script while writing the manual
    so it should work :)
    there --------------------> https://sites.google.com/site/mcasualsdazscripts3/mcjchangeorientation
    954 x 534 - 55K
    WOW... awesome. Did Larry actually have a conversation with that cat? lol
    Casual said:
    Oh my!
    Thank you ;-)
    well not really though i'm sure Larry had guests like Kermit :)
    ( didnt spend too much photoshopping effort of some images back then )
    640 x 480 - 17K
    Hehehe... Mysterio Cat!
    That's so good!:)
  • TugpsxTugpsx Posts: 808
    edited January 4
    Welcome to 2026. Here is an updated version of ChangeOrientation that works in DazStudio 2025. This is a very useful tool that allows you to change the pivot point of one second selected asset to match the origin of the first selected asset.
    Example make a  cube orbit a sphere .
    437 x 614 - 56K
    zip
    zip
    mcjChangeOrientation6.dsa.zip
    12K
    Post edited by Tugpsx on
