dForce Side Bob Hair for Genesis 8 Female(s) Only seeing a grey box when loaded.
mats76
I tried to use the new dForce Side Bob Hair for Genesis 8 Female(s) but the Only thing showing is a grey box when loaded. The install size seems little bit small 90mb compared to Linday other dforce hairs 600mb, 800mb and 1,3gb.
Are you using DS 4.11 or later, and have you installed... I think it's called dforce hair essentials or similar? The boxes like that are usually the result of no geometry I think, if you have a current version and dforce hair essentials installed, I would try removing and redownloading the hair. This hair appears to be the new type of dforce hair, where many (all?) of Linday's previous dforce hairs were actually geometry using the cloth dforce settings.
If the page is wrong and this isn't strand based hair, I'd say it's an install issue.
That could very well be the reason since I am still on 4.10. I thought I saw "requires 4.9 or later" on the download page, now that I look at the page I see that "4.9 or later" was the requerments for daz connect and not the product
Many thanks
