Exporting OBJ does not collect maps.
Angel_2232633Angel_2232633 Posts: 1,204
So I'm trying to export an object with maps selected. However when I expor it does not actually collect the maps. It should collect at least the diffuse maps but it does not. I dont know why. Can someone help me? It dont even create a maps folder. It acts as the defaut setting.
Post edited by Angel_2232633 on
  • You need to check the 'Write Material Library' checkbox.  The diffuse maps should then appear in a folder named 'Maps' within the folder to which the OBJ and MTL files are exported.  At least, that's how it works for me in DS 4.11.0.383.  I haven't tried it in 4.12: if you're using that and it still doesn't work with the checkbox checked, then maybe it's got broken in the latest version?
