PNG Seq first 4 frames black??? Carrara 8.5 FIXED
Box8068_31c338ee4bBox8068_31c338ee4b Posts: 292
edited October 2019 in Carrara Discussion
Hello All
When rendering in Carrara 8.5 My first 4 frames are solid black.
I've never seen this before. ( I might normally render in 8.1 I don't remember)
Thank You
Brad
Post edited by Box8068_31c338ee4b on
    do you have any keyframes at 4 ?
    mebbe something wandered
  • Yes I believe I do.
    edited October 2019
    you could start your animation at frame 4.  in the render output settings.
    or you could drag the triangles at frame 4 to frame 1.
    anything you moved at frame 4 will automatically keyframe.
    for safety i usually set the camera's tick box to not animate. then turn it back on when ready for the camera work.
    Post edited by Mistara on
  • Never did figure this out, guess I'll try back in Carrara 8.1
    B
  • Fixed! There was a motion blur set in Scene Settings in the assemble room.
    This caused both 4 lost frames and the blur. On a different note this blur seemed to render faster than using motion blur in the render room.
    B
  • DiomedeDiomede Posts: 15,466
    B
    Glad you got it sorted out.  Interesting bit about the render time.
