Adjust rigging to shape doesn't work. why?
TheCedizTheCediz Posts: 172
Okay. I am very tired. It is problem after problem. First off, where can I get detailed information about rigging parameters, erc parameters, and the geometry tool. The little videos on youtube are not enough. I need to know where do YOU learn this stuff. I can't imagine figuring the whole thing by myself.
But here is the pressing issue. I created a morph that implies a slumped posture and I need to adjust the rigging to shape. But when I do, this distortion happens. Something makes it so the "adjust rig to shape" button doesn't do its job.
thank you
Post edited by TheCediz on
  • I just bought Shape rigger plus from Zevo and it does not work. Nice.
    I would be very grateful for any advise or hint for what could be the problem here.
    thank you
    Well we do learn a lot by ourselves as well as by asking questions and with some team work, help each other learn.
    I do not have the product you are talking about so can't help with that.
    I show a very basic "how to" adjust the rigging, apply ERC, and then save the morph in the tutorial I released today. Here's my post.
    Basically: Have the morph dialed in 100%. Right-click on a bone and Adjust Rigging to Shape. Then go to the slider, right-click and select ERC. Make sure the 3 options are checked, I do not play with the other options in there. Just check off the 3 boxes and Accept. Then as the morph is dialed out and back in, the bones should be following. If all is well, then zero the morph and save the morph.
  • TheCedizTheCediz Posts: 172
    Hi thanks for your answer. But I know about "rigging to shape". Issue here is that it does not work. It messes the hands mesh I dont even wanna know how it looks if I pose the figure. What could cause that? What makes "rigging to shape" nit work and how can I fix it? Much thanks in advance
  • 3WC3WC Posts: 1,166
    Unfortunately, adjust rigging to shape is sometimes a bit "fiddly". You may have to adjust your bone positions manually and then do the erc freeze.
