Problem with importing models
ShakibaNikkhoo
Hello
I got problem with importing some of models. the problem is some of mesh parts disappear when I import them into Daz. Does anyone know what the problem is ??
screenshot is attached
What is the model from? What format did you use to import?
Nobody can help you unless you give more details. there’s not enough in your original post to diagnose the problem.
Richard asked you some questions, start by answering those...
edit: and for the record, you’re posting to a user-to-user forum, this is not Daz tech support. You can open a support ticket using “help > contact us” in the site top menu.
Where are the models coming from, though? It may be a consequence of soemthing in the source.
Sketchup exports have in the past been problematic in some cases.
one thing to check for is the opacity is not turned all the way down. I have imported a few meshes where the opacity/transparency was at 0% thus making the object invisible.
Just checked against C4D. D|S definitely does not import all meshes in that file but damn, this thing is an unholy mess.
