Sheer Greatness!
woody2woody2 Posts: 90
Has anyone else got this product. I bought it yesterday and have no Idea how to use it. when I run it all I get is a square box around the person I am trying to use it with. I wish that they would put a little tutorial on how to use there products. I am thinking of asking for my money back if I can't get this working.
thanks for any help
woody2
  • SimonJMSimonJM Posts: 6,085
    You get (I think) three Shaders, so you'll need to have the material zone selected, then navigate to the Shader you wish to apply.
    Depending on how you get around in DS you may get to in a different way to me, but under Content Library it will be in My Library > Shaders> Sheer Greatness for one Script and in Fishnets and Lace sub-folders under there for the other two.
    They all give options of various colours and the Fishnets and Lace Scripts/Shaders give the option to pick the Opacity map for hwat pattern to have applied.
    Under Surfaces tab in Presets you can find them under Shaders> Fabric
  • woody2woody2 Posts: 90
    Thanks Simon. I just found the pdf on it and was trying it out but when I go to load a shaders it gives me a error and says to check the log. I have no Idea were the log is keep. so I can't load it to run through the tutorial that is in the PDF. I have installed it twice just to make sure that all was were the files said they should be. guess I will have to keep playing around with it . It looks like it would be a good program if I can just figure out how to use it and install it. it might be my set up not sure. the daz program itself is on c drive and the My Library in on a different drive but everything points to the library. C drive was getting to full so I moved everything but the program . I might just reinstall daz and put it on the new drive also. maybe that would help, not sure anyway will keep trying it and see if you have any more help please please it along
    woody.
    The log file can be found from Help> Troubleshooting> View Log File ...
  • DecoyboyDecoyboy Posts: 516
    I hope you figure things out. Sheer Greatness is a nice product. Zev0 does great work. here is a very very quick sample of the product. the pants are Sheer leggings with tears added to them, the shirt is done with shaders from it.
    786 x 755 - 555K
