Is it just me?
LeatherGryphon
Is it just me or has anybody else noticed that forum references to DAZ Studio are finally not as frequently calling it just "DAZ"? (especially among the newbies) Have we finally broken the bad habit? If so, what happened? Are there now so many versions of Studio that we have to identify which Studio we're talking about? 8-o
Not complaining, just observing.
I always said "DAZ" but I was corrected (not on this forum) that I should say "Studio" and not DAZ as DAZ is the company and studio the actual software...
I tend to not correct New Users so much as pointedly refer to Daz Studio in my replies,
I kind of liked D|S, but that was already falling into disuse several years ago.
I found the | symbol too hard to just thrown in, not on my keyboard, needed character map
I call it studio or DS
but I am a Carraraite and a bit of a Poser and iCloner who uses Daz content so Daz for me has always been the company and source of models I use, not the software.
Yes after my first reference to it by it's full name I then will start using DS, as it is obviously easier to type than DAZ Studio.
DS for me too. Sometimes I'll type out DAZ Studio....
My preference as well. I only use DAZ to refer to the company, and then I often would use DAZ3D just to be certain folks knew exactly who/what I was referring to.
Yup, DAZ3D is what I type out so there is no mistaking what or who I'm referring too! lol
I like to type out "The Studio 3d posing program produced by the company Digital Art Zone-"
NOT! I like DS too! :)
DS sounds great. Poser can be considered PS but that gets easily confused with photoshop.
Well ... I use Daz studio for the software, and Daz 3D for the company.
Greetings,
I've been random in my usage, but I really like D|S. But I'm a programmer, so the pipe operator is something I type all the time.
-- Morgan
I had no idea that ' | ' was called a pipe operator!
I just usually type D/S when I'm referring to DAZ Studio.
Greetings,
Pipe, bar, and 'or' are its three names that I can think of off the top of my head.'Pipe' when it's being used as a..well..pipe, in a Unix-y sense. 'Bar' when it's being used as a separator, and 'or' when it's being used as either bitwise (|) or logical (||) 'or' in most programming languages.
Anyway... 'D/S' has totally different connotations to me, due to my misspent post-college years. 'DS' less so, and is a primary alternate. 'D|S' makes sense to me, but I keep feeling like other people are going to cock their head confoozedly at the screen when I write it. 'Studio' seems too broad, and 'DAZ' is Just Wrong(tm).
Those were fun paragraphs to write, with all the the use/mention distinctions going on.
-- Morgan
On most of the keyboards I've seen, you can get the pipe character by holding down SHIFT and typing \ (which is generally just above the ENTER key).
For anyone who was a) Interested and b) didn't know....
I was always partial to D|S myself...
That only works on US layout. on UK keyboards it tends to be next to the shift key, between shift and Z
I'm thinking of referring to daz studio as "Fusion-powered Muffin Bomb 4.x"
I think it will catch on...
As cypherfox pointed out, programmers came up with some bizarre nicknames, usually monosyllabic, for things they use a lot, instead of going with conventional 3-5 syllable names like "exclamation point" or "underscore"
! - bang or wow
^ - hat
_ - base
$ - cash
This is a famous poem, "Hatless Atlas"
^<@<.@* <br /> }"_# |
-@$&/_%
,#"~|)^G
It translates to
hat less at less point at star
backbrace double base pound space bar
dash at cash and slash base rate
wow open tab at bar is great
semi backquote plus cash huh DEL
comma pound double tilde bar close BEL
The page I grabbed that from says it can be sung to the tune of "Twinkle Twinkle Little Star" but I remember it as being done to the "Alphabet Song"
Actually if you listen to the tune of the Alphabet Song and Twinkle Twinkle Little Star, they are the same (or at least reaaally close). Didn't notice it until I tried it both ways and was like huh...the song sounded the same no matter which one I picked as the tune LOL Never noticed that before either DOH! :)
HMMM I like that one, may have to start using it! hehe
SAPI4 TTS cannot read the Geek language and SAPI5 not even the characters
http://youtu.be/zMW9yJeg3GE
SAPI4 thinks the pipe thingy is a vertical line too
I did not know that people in the United Kingdom use different keyboards. I learned something new.
Yes. the layout is just slightly different for some of the keys. I had been quite happily typing away on this keyboard, (which happens to be the American layout) with no problems as I touch type, until I needed to use the back slash in order to be able to use the MS IE 11 fix and had to use the command panel to do it. Ended up changing the language from English UK to English US in order to do it, and now I have to think before I type @ and # because they aren't where I expect them to be and I have to use an alt character to get £. and can't type '' with one key press.
Wasn't it dear old Winston talking about "two great peoples divided by a common language?" :lol:
In Unix, not only is the '|' referred to as a pipe, we also have a 'tee' command, which is referred to as a pipe fitting. If you want to give a Mac user a heart attack, you can bring up a Unix shell on their machine and start typing cryptic Unix commands that actually do something. It scares the heck out of them. :gulp:
For me, DS works fine. Since I'm stuck on Daz Studio 3 for a while, I refer to it as DS3, which won't confuse anybody.
Yes. the layout is just slightly different for some of the keys. I had been quite happily typing away on this keyboard, (which happens to be the American layout) with no problems as I touch type, until I needed to use the back slash in order to be able to use the MS IE 11 fix and had to use the command panel to do it. Ended up changing the language from English UK to English US in order to do it, and now I have to think before I type @ and # because they aren't where I expect them to be and I have to use an alt character to get £. and can't type '' with one key press.Hey, I heard the UK keyboard also moves the U immediately after the O so they can be typed together in the proper order.
Just kidding ;-)
Just kidding ;-)
ROFL :coolgrin:
Yeah, "|" has always been "pipe" to me. I'm an old Unix wizard. Loved "piping" commands together. Damn, UNIX was powerful! I miss it. :-(
UNIX wizards could cast spells of gobbledegook that would befuddle any naïve onlooker. Pure magic! :-o
Long, long Before UNIX (early 70's), I worked with the Xerox Operating System on a Xerox Sigma5 mainframe, where the "!" was a lead character to all system commands input by punch cards. So you used the expression "stick a couple bang cards in front of your program" a lot when advising student programmers.
I need to specify whether I am using Daz Studio 3 or 4.6 in other threads. People ask me, "Are you using Studio 3 or 4 with advanced spotlights by Age of Armour?" I use generation 3 and 4 figures in Studio 3 and 4. I should stick with version 4 because I can use the new sub surface scattering, advanced spotlights and Luxus.
Then the question becomes, why am I still using Daz Studio 3? Uh...
