Genesis 8 Male not showing up on Smart Content
RO StudiosRO Studios Posts: 107
edited September 2019 in Daz Studio Discussion
[Genesis 8 Male not showing up on Smart Content] Just to say first that I have the support files, but, just says it's for Genesis 8 Starter Essentials instead of the correct name as the female counterpart when I downloaded the figure. I'm not sure if there's a mistake or that just how it is..?
  • How did you install? Genesis 8 Starter Essentials is the product name, but it is split into male and female zips in DIM.
    I installed it manually.
  • Well, as I said the correct name is Genesis 8 Starter Essentials so I'm not sure this is an issue as such - unless you can't load the figure, in whichc ase I'd suggest doing a DIM or Connect install.
    Alright, I'll do it that way. Thanks for the help, Richard.
  • cm152335cm152335 Posts: 421
    when manualy install, you must click on DSX file found in the "runtime/support/" folder of the decompressed zip
    that "set" the product in smart content
    or after manualy copy files,
    execute the RE IMPORT METADATA
    Post edited by cm152335 on
    Thanks, I'll keep that in mind when doing that. :)
