Kanade Hair on Luna misaligned what to do?
Tspirit
Kanade Hair has a break in the pony tails when I apply it, does anyone know how I can adjust it and fix the misalignment?
Thanks in advance. Hugs
That's probably down to the way the morph is being projected into the hair from the figure - the head is bigger relative to rthe rest of the body so there's an abrupt chnage when the projecting mesh goes from head to neck. You probably need a custom morph, though you might be able to use a dForm or two with weight maps to pull the tails straight.
You can also parent the hair to the head without fitting it. Just ajust the size of it and the position, then set the hair collision to your model
True, and often the best solution - sorry for not suggesting it.
Hi All,
I am having the same issue with the hair but I cannot figure out how to do what TheCediz suggests. Can anyone offer me a little more specific instruction. Thanks in advance!
