is there a utoob tutt on how to install genesis 3/8 starter essentials?
even if it's not manual.  i guess a video on how to use and install DIM?
    1. Install DIM is just like installing any application
    2. Run DIM and I think, on a clean system, it will ask where you want you content
    3. Log in
    4. Select content by using the check boxes, or the master check box at the top, click Process Queue button
    5. Start DS, if you are not using the default paths in DIM you will be given a chance to add them to DS
    6. Use the content.
    thanks.
    but i'm responding to a comment on one of my yutube tuttorials asking how to install genesis3.
    responding with a yu tube link would be an entry point.
    I'm assuming the person doesn't know a thing about DAZ and Daz Studio.
    i can't do a tutorial on dim, it doesn't compute in my brain. i'm still a DOS jockey
