Daz crashing when translating ( Moving ) objects
davegvdavegv Posts: 166
I am having a ongoing problem with daz crashing when I am translation a object ( More often a character, both G3 and G8 )
I can use the translation tool gizmo ( The xyz tool that shows up on screen ) or the sliders to translate.. and I seem to get way too many crashes.
Nothing is noted in the error log -  I have a Threadripper 2950x, 32 GB ram, RTX2080ti. I use a number of other 3d programs ( Max, Maya, ZBrush, and never encounter a similiar problem )
I have Daz3d rel 4.11.0.383 and also the rel 12 beta and the problem exist in both. I have latest NVidia Drivers. The screen is in texture view mode ( Not iRay preview ) These are NOT "heavy" Scenes.
Any help or suggestions would be most appreciated
Added : What does the "Click here to toggle whether this property overrides any controllers" mean? It is located to the left of the Lock symbol on the translate slider ( Only the y translate has this...
Post edited by davegv on
  • I'm not sure on the crashing, and I'm not certain on the other question - I think it may be the chain icon, which cotnrols whether any remote control links are applied (one property can be set to influence others, that's called ERC, I suspect that at least one of the shapes on the figure you are using has links to the y control to make sure the feet stay on the floor when it is applied; clicking the chain icon, turning it into a broken chain, would stop the correction from being aplied.
  • davegvdavegv Posts: 166
    edited September 2019
    Thanks Richard for the reply. I cleaned up some morph errors appearing in the log file - So when i load the scene the log shows Zero conflicting morphs, ect. This didn't help the perodic crashing when moving a figure. I am stumped, but, it is very frustrating trying to work like this. Recently when I clicked the chain icon you referred to above it instantly crashed . ( Thanks for the explanation just the same ) on top of that problem I am testing my new RTX2080Ti ( 3 days In ) I read the impression's others have with the speed increase from Rel 11 to Rel 12 but a typical sample scene I used for comparision gave me this : Release 12: 51minutes, 36sec VS Release 11: 1 hour 13min - So I am not that impressed with the speed increase in IRay, BUT, it is as advertised a 15-25% increase - I'll take that.. I was just wishing for more....and that same scene was also within 10 minutes of what my previous GTX1080 performed. But I have discovered that the VRay Next4.o release is BLAZING fast within 3DS Max ( a render that took 26 minutes on my previous GTX1080 is finished in just 12 minutes on the RTX2080Ti. ) So, I am very, very happy with that. The VRay interactive viewport in Realtime will render and not even blip while constantly updating the progressive render while spinning the entire scene in the viewport . Quite impressive. Anyway, not to get off subject to far. If you or anyone have any idea why this Translating is causing a crash I'd sure like to know. I used Rel10 Daz3d and even Rel11 forever without this sort of conflicts. Puzzeling for sure.
  • Which benchmark is that? The times seem too long for the SickleYield scene, if the GPU is actually being used.
    No, Not the Benchmark scene used in the forum discussion /  or the SickleYield scene. The scene used was one I choose of my own as a typical scene/render that i would do. Typical of my workload. Still no luck on the crashing problem troubleshooting. A completly empty scene with just Genesis 8 female I can freely move her along the xy axis useing the move tool on screen quickly with no problem, but while testing this i quickly rotated her then went back to a xy move and as soon as i attempted the move - Crash, out like a light.  I have tried every driver from 430.86 up till current ( Mostly the studio drivers, because I use a number of other 3D programs they support as well )  The empty scene told me it is likely not due to a large scene or another item in the scene. And I have narrowed it to the G8 Characters, Genesis 3 seems to not cause the problem. Quite a puzzle, and not a easy one to troubleshoot. Other than the problem described I am totally impressed with my new RTX2080TI (EVGA)  Impressive performance with my 3D apps. No game testing, as I have a separate game system (EVGA GTX1070TI) surprise
    Still trouble shooting this problem when I move a character in the viewport sometimes I will get a random crash. Experiment: A completly empty scene with just Genesis 8 female I can freely move her along the xy axis using the move tool on screen quickly with no problem, but while testing this i quickly rotated her then went back to a xy move and as soon as i attempted the move - Crash, out like a light. I cannot duplicate the crash with a Gen3 male or female character? I did go into Draw settings and change the Manipulation draw style to: switch to wire bounding box. While translating the character (moving) the character reverts to a wire mesh bounding box. I Ran several test cycles and have not caused a crash yet....
    Edit: It crashed with this test as well..... Back to square 1
    A question I have for you Daz Guru's: What are the best performance settings in the NVidia Control panel for Daz3d - In particular for viewport performance and of course IRay as well.
    The only two settings I have changed specific to Daz3D are:
    1) ensure that the RTX2080ti is selected under Cuda - GPU
    2) Open GL renderingGPU = RTX2080Ti
    Thanks for reading and I sure could use some suggestions...
    edited October 2019
    I have I believe solved this problem.
    Again, the Genesis figures do not load with every morph they have, they are just references to the actual morph data.
  • cmrn87cmrn87 Posts: 0
    OP, how did you fix this, I am having the same issue, Mac OS
