Adding to Cart…
I'm not sure what happened between now and yesterday, but I was rendering fine. Today I pose the character, hit render, and I get blank images. I have been searching for a solution but not having any luck.
If this is Iray one obvious possibility is an automatic driver update. Failing that you erally need to prvide a lot more information - Iray or 3Delight, OS, system specs etc.
If you get a transparent render: For low angle shots below the ground plane remember to switch OFF the "Draw Ground" option in the Render/Environment panel. (Gets me every time)
THANK YOU. Others had suggested that it might be a ground plane issue, but they didn't say what I should do about it. Very grateful to you, man.
