about Muelsfell Multilayer Iray Terrain Shader
2»
  • Oso3DOso3D Posts: 15,116
  • MendomanMendoman Posts: 404
    edited September 2019
    Is there a way to add glossy map to shaders. I use 4x shader for my terrain, and I can't find it anywhere. Building a ground shader for relatively flat surface without access to glossy layered weight input ( which I assume is set to 1.0 or max as a default ), is kinda hard. Everything looks really glossy, and playing with reflectivity and roughness is not not enough to offset the problem. Even when reflectivity is set to 0 and roughness to 1, it's still matte glossy.
    Here's images to show the problem. Normal shader with glossy layered weight at 1.0 ( both images have reflectivity at 0 and roughness at 1 )
    And here's the same terrain with glossy layered weight set at 0.0
    So is there a way to set that glossy layered weight somewhere in the shader, since all my terrains look too glossy?
    800 x 566 - 372K
    800 x 566 - 407K
    Post edited by Mendoman on
  • That's a known issue I've had on my to-do list.  I'll need to submit a product update to address it.
    I've just now bumped doing that up my priority list (it was at #4, it's now at #2).
  • Thank you for a quick response, and other than that glossy issue, I really like this shader. With that glossy fix, this is my goto for terrain shading. Can you give any ETA for the update?
  • I'll be working on it this week (decided my #1 priority project could actually benefit from the update, too), but I have no idea how long it will take to pass QC and the product updated.
  • Ok, thank you for the information and a quick response again. I'll continue my project once the update comes... oh, and as I side note, I know it's not your responsibility to answer here in the forums, but it's really appreciated. Great customer service and a happy customer here yes
  • The changes were relatively easy to make as it turns out, more a matter of exposing the parameters and plugging them in rather than creating them from scratch, so this has already been submitted for approval just a few moments ago.
    I don't know how long it will take to be approved and live as everyone is still very busy with PA sale releases (assuming they don't find any mistakes in how I handled it).  Give it at least a couple weeks before watching for any update to appear in DIM.
    I will say the shader works MUCH better when you have access to the glossy layer weight parameter; that really should have been available from the start.
  • The QC team got on this right away.  I'm sure it being only a small change was an important factor.
    The updated version with Glossy Layered Weight parameter exposed on the shaders is now available in DIM.
  • Thank you very much. I still have work to do with my terrain, but the shader works beautifully nowsmiley
    2036 x 1440 - 2M
  • veenveen Posts: 140
    do you need third party textures to generate a terrain shader?
  • lilweeplilweep Posts: 2,873
    edited December 2019
     You could use the textures from the ones sold here (the terrain shaders in the daz store).
    There are also freebie textures for shaders/pbr materials at various places online.
    You will need a third party 3-D painting program (or photoshop etc) to make the masks for your terrain though.  I mean, I dont have this product, but im just going by what has been said in this thread and in the documentation.
    Post edited by lilweep on
