The subtree part will only show once you have run transfer utility. Did you run that already?
Yes. But I just tried the same procedure with the Genesis Male (not the Genesis 8), and THAT WORKED! So it might be an issue with the G8M character. I'll try to re-install it.
I don't know what I'm doing wrong. Now I can import the eyebrows, and after transferring them to the G8M character, they sit correctly in the node tree, but they remain invisible. The shader settings look correct.
Wait ... the node tree still seems to be broken. It has the following elements under the eyebrows node:
Sigh ... I'm one step further, but still unsuccessful. I've been able to export and re-import the brows by fixing the settings in the export dialog (in 4.11 - it does not work with 4.12 Beta). Now I can actually see the imported brows, BUT: They don't fit the G8M, neither before nor after applying the transfer utility. The are hovering somewhere (approx. 2 cm) in front of the forehead (that's where the morph's forehead is). I have no idea how to fix that. :/
Since this Thread is up again I just leave a short comment - i really love this set. I use it for all my males and this is very versatile, too. Lots of different shapes.
Absolutely terrific product -- love it! Ditto for the Beautiful Brows.
Where is the PDF documentation, though? I downloaded through DIM but can't seem to find anything under the DAZ ReadMe's subdirectory for either product.
- Hip/Pelvis/Left Thigh Bend/ ...
- Hip/Pelvis/Right Thigh Bend/ ...
- Hip/Pelvis/Abdomen Lower
But the latter is an empty node.
Sent you a site mail sofax :)
Thanks for your help! :)
+1
Very nice job, indeed.
My G8 males can't do without these ;)
Laurie
Feelin the love :) Thanks guys!
I will post it here on page 1 for everyone! I am not sure where or how the pdf didnt end up where it was supposed to be.
Thanks. Also I just ran across this comment post which helps a lot:
https://www.daz3d.com/forums/discussion/comment/4273381/#Comment_4273381
