Having trouble with pwGhost shaders
I bought pwGhost shaders today, but when I highlighted the surfaces of the object and double-clicked pwGhost, it doesn't work.
I am wondering if I may have put folders from the package in the wrong places?
  • FishtalesFishtales Posts: 6,227
    If you are working with Iray they don't work they are for 3Delight.
    Did you also have the object selected in the scene tab?
  • I had the surface selected.  Plus, I am pretty sure I had my render settings to 3delight.
    Yeah you need to select the object/figure AND the surface:)
  • scorpioscorpio Posts: 8,533
    I just checked and its working for me in 4.11.
    Did you install using DIM or manually? if I remember correctly its needs installing slightly differently to other content so a manual install may not have worked.
  • I downloaded it manually.
    There are files that need to go in the application folder, not just content, so it's better to use Install Manager.
  • I did take the Install Manager route myself.  The pwGhost render works.
    I have to figure out how to make a figure look ghost-like with an edge effect.  How can this be possible?
  • NorthOf45NorthOf45 Posts: 5,793
    Have you tried the presets in the Resources folder? One of their standard tricks is just that, edge effects, like on Phantom or X-Ray. You have to render (3Delight) to see the effect, the OpenGL preview is not suitable.
