Brint Martin
I"m having a problem with loading a figurers. I can load one figure anload them up with cloths and what ever. When I load another sometimes I can't fine example hair to load for thtat charcture, I figure well , maybe I don't have a hair that works on that characture, So I delete that characture from the scene, and from then on that is the only characture that will be a option for me to choose form. I then have to close down Daz and try again, and reopen Daz again then I have pretty much and characture I want, but from then on I start having a problem loading another figure. Just started having this problem, and now it is consitant at not letting me get all the things I want to load. I have DAZ 4.11. I have a number of group of people that worked before, but now I have this problem.
Please give your threads descriptive titles, rather than what I guess is your name - I nearly deleted this one as a duplicate.
Do you mean in the Smart Content pane? If so, try making sure you have nothing selected and you should see all the things that can be loaded on their own, or make sure you have the figure you are working on seelcted. If you are wnating to see products made for other figures, intending to AutoFit or whatever as a conversion, then uncheck Filter By Context at bottom-left of the Smart Content pane.
I restarted my computer and it worked correctly their after. I havent used the for along time. When I was going to Explain the problem in my name. I thought that was odd. I havent used DAZ Studio in quite a long time, I'm still learning my way around in it.
Would you be ok with us changing the title of your thread to "Problem Loading Figures (Solved)" since restarting seems to have corrected the problem?
As a long time Studio user, I can attest that sometimes when things keep going wrong or giving you unexpected results that restarting Studio and/or the computer can clear things up.
