Crystal Ball? Help
vonHobovonHobo Posts: 1,715
https://www.daz3d.com/ubersimple-gems-and-glass-merchant-resource
I purchased this product because I wanted to create a crystal ball (as shown on the product image page, bottom left). However, there is no smooth sphere in the shapes provided with the product, just a variety of faceted gemstones and a glass goblet.
Is there a simple way to create a completely smooth round sphere in DAZ that I can apply these shaders too, or do I need to find another product that has a crystal ball prop?
The gemstones are really beautiful, so I will keep this product, but I need a crystal ball. sad
Post edited by Chohole on
    edited September 2019
    Any sphere will do. And yes, Studio can provide one.
    'Create A New Primitive' in one of a couple of ways: From the drop down menues or from the icons. Then select 'Sphere' and play with the options, like diameter, etc.
    1108 x 800 - 206K
    Post edited by frankrblow on
  • Try using a sphere primitive and apply the shader. You might have to go into your product library and select the shader from there in order to apply it to the primitive. I haven't been able to figure out how to apply shaders to primitives from smart content and always have to locate them in My Library, My Daz3d Library, or Products A-Z and apply them from there after selecting the surface.
  • vonHobovonHobo Posts: 1,715
    Thank you Dragonfly. It worked. Not quite perfectly round but close enough. I just use this as reference for my paintings, so it doesn't have to be perfect. smiley
    Magog: Make sure you have the prop selected in the Surfaces Pane before you apply the shader, otherwise nothing happens. (see my screenshot)
    1920 x 1031 - 572K
    You are welcome, Von Hobo. And you can always create a sphere with more sides/segments, if you want it less angular - or just find a ready made sphere/ball that suits you.
