HowieFarkes Valle Alpina, Noble Pines, and Byodo In questions
Does anyone own any of these? Valle Alpina, Noble Pines, or Byodo In.
The Howie Farkes product Valle Alpina claims to be a Carrara product, but in the details it states "This product can not be used with cameras in Carrara."
Does anyone know what this means? The statement doesn't make any sense to me at all.
Secondly, all three of these products feature mountains. Are the mountains actual terrain objects or just background images?
I have "Howie's Snow Scene" and know that those mountains are all actual terrain objects. But I can't tell for sure about these other three products.
I'm looking for a rich, tree filled mountain environment that I can modify in Carrara to suit my needs. (Yes, I know I could try to make my own from scratch, but well.....I'm no Howie.)
  • OnlyLuvsCatzOnlyLuvsCatz Posts: 22,347
    I have all of them and have rendered videos with cameras you do need to hide or delete the fill bit in Vale Alpina
    has a few changes
    There are some Byodo-in shots in the render thread
  • SileneUKSileneUK Posts: 1,536
    edited September 11
    In Vale Alpina, the mountains are mountains, not backgrounds. If you buy it, go to the top view and you will see the huge terrain.  Here's a screenie of it in the shader room.
    There are lots of replicators in there for the trees and meadow along the river.  True only the  typical Camera 1 shows up.  Surely you can add more as you wish.  I usually just copy Camera 1,  and paste it, the move to where I want and rename it.  Some PAs give us loads of cool cameras. Like TangoAlpha and PhilW.  I have to mess with the lighting as it uses Realistic Skies.
    Just my 2p.  Others will have more techinical info.  smiley  Silene
    ETA:  Like Wendy!    Also, I have Noble Pines which is a bit faster to load.... but I got it in a package.  I prefer VA and have stripped out some of the trees which makes it easier for me and I didn't need all those trees.
    601 x 427 - 111K
    Post edited by SileneUK on
    has a few changes
    I remember you combining it with Harpsburg some time ago... nice effect. Big file? surprise Silene
    edited September 11
    That was a 360 BG render as a background for Harpsburg
    this is the scene simplified a fair bit with a Vanishing point castle that one in Germany
    Post edited by OnlyLuvsCatz on
  • MystarraMystarra Posts: 32,357
    i'm ready to cat like pounce on the byodo in and maple meadows.
    https://www.daz3d.com/maple-meadows
  • de3ande3an Posts: 876
    Thank you Wendy and Silene for the info and examples.
    When I found that all three were on sale I went ahead and got them all.
    Noble Pines and Byodo In are heavy scenes but workable.
    However Valle Alpina seems to be super heavy! I need to choose "Bounding Box" for the Assemble room display to navigate the scene without awful sluggishness. But I can't seem to get a render started. It gets stuck "Filling Grids" I think. Waited a long time but no progress. Have to Force Quit (on Mac OS) to get out of it.
    Wendy, you mentioned something about needing to "hide or delete the fill bit in Valle Alpina". I don't understand what that means. Could you explain?
    edited September 12
    There is a section of trees called fill
    Howie said they are there to fill in for set shots but they obscure it if you want to move around
    yes need to use bounding box to move or hide lots, it's very heavy
  • Bunyip02Bunyip02 Posts: 3,080
    edited September 12
    Worth the struggle !!!
    1800 x 1300 - 5M
    Post edited by Bunyip02 on
    Thanks Wendy. I found the "Forest Detail Fill" group. Turning it off helps a little, I think.
    So far, though, I've not been able to render anything except the default scene. I suspect it's my computer's fault, but you'd think a 3 GHz 10 core Xeon system would be able to do better.
    Oh well...
    Nice. How long did it take? What renderer are you using. I only have the Carrara native render option.
    It is incredibly heavy, if I recall I actually saved a second scene with it only the camera and terrains and set my shots up in that then imported that camera, not the first time I have done so on a scene.
    edited September 12
    I did that render over a couple of years ago, so I don't remember the actual time except that it took a while.
    I deleted the "fill" and saved the scene.
    From memory I took lots of baby steps, slowly rotating or moving up and down, in and out, as Wendy said it's a very heavy scene.
    The Eagle when I imported it also took some sorting out to get it into position.
    The Carrara native renderer is what I used, but I then took the finished render into Topaz to make the colours stand out a bit more with post work.
    Edit:- Silene's idea of copy/pasting the camera is good advice as well !!!!
    I
    That's the best render of VA I have ever seen!!  Makes me was to play with it again.  IIRC... I stripped a lot of stuff out of it and saved it as a smaller sized version, but it is hiding from me right now.... likely got left behind on my old custom browser file. Wonder what else is in there LOL!
    I have a lot of trouble adding cameras with the Carrara drop down tool... I found it much easier just to copy and paste the main camera and put clones all around with appropriate names.
    smiley Silene
  • DiomedeDiomede Posts: 9,813
    Excellent render.
    That's a great tip for setting up shots. I don't think I would have thought of it. Thanks for sharing!
    I
    smiley Silene
    Thanks
    Excellent render.
    Thanks
    Making progress with your renders ?
    Once you work out how to move around you should be able to get some renders done !!!
  • with habsburgic castle
    1000 x 1300 - 2M
    Looks great !
    alpina, lag from render room back to preview window
    default scene render on 6 cores was 20 minutes
    byodo inn, default scene render 1 min and half.
    trying lighten the lag in alpina.  so far removed the fake gi group, lowered the replicators from 1,500 to 300, removed the dead trees.
    1030 x 431 - 89K
    1151 x 434 - 86K
    500 x 650 - 413K
    712 x 445 - 28K
    Remove translucency on the leaves
    reduce smoothing on the trunks
    edited September 20
    thanks
    i can't find the trunk smoothing setting  - found a smoothing
    trying to remove the backdrop, saving it to tray first.
    Post edited by Mystarra on
    edited September 20
    Mystarra said:
    thanks
    In the tree room under the preview window where the show leaves etc checkboxes are there is a smoothing slider,
    think jusf called smoothing but it does the trunks etc, thats where it's obvious
    I put it right down to 2 you get triangular branches and trunks so tree close ups its not great but otherwise OK
