Victoria 6 & Michael 6 HD Purchase Issue
Ok, Im trying to purchase "Victoria 6 & Michael 6 HD Bundle", but everytime I try to add it to my cart it says:
"The maximum quantity allowed for purchase is 1."
But my shopping cart is empty and I do not own the new Michael 6. I do have Michael 5 and Victoria 5 for genesis 1. Is that the issue? How do I upgrade to http://www.daz3d.com/victoria-6-michael-6-hd-add-on-bundle
Post edited by Teriander on
That has happened to me, as well, and quite often. In my case, it's because I added the item to my shopping cart without being logged in. In order for it to work for me, I logged out and then logged back in again. If it still doesn't work, add something else to your cart - then usually both items show up. Then delete the item you added last.
Thank you Mari-Anne, adding a random item has fixed this issue. Thanks again!
That wasn't the issue as far as the shopping cart was concerned, but please do note that in order to make full use of the HD add-ons, you will also need to purchase Victoria 6 and Michael 6. And if you haven't done so yet, you'll need to install Genesis 2 Starter Essentials which is free, and should already be available in your Product Library.
