Double Tails hair (Question)
The materials does not stick, i choose the base hair and click on the materials and nothing.
I dont think i understand this hair blending thing.
Post edited by SeventhRoar666 on
Blending effects usually require rendering to show (or Iray preview mode) - are you doing that?
Also, with all of OOT's hair, you need to start with the "Apply This First" shader before you start applying the base colors. The "Apply This First" loads OOT's custom hair shader while the Base, Blend, and Mask presets are just adjusting parameters of the shader.
Thanks, that was the problem. I used wrong version of the hair. I did not use the base version.
Richard, Thanks, the iray preview helped when it came to the wearebles. Because they did not change visibile.
