Post Your Renders like it's the year 2020!!!
1…8485878990…100
  • StezzaStezza Posts: 9,261
    Mystarra said:
    has anyone rendered inside the
    https://www.daz3d.com/world-gardens-byodo-in
    is the one thing on my wl for this pa sale year
    I never got that one... dunno why.. looks awesome, may do the same wink
  • Bunyip02Bunyip02 Posts: 9,345
    edited September 2019
    Wonderful scene, a bit heavy on computer resources though - but definately worth it !!!
    800 x 650 - 736K
    Post edited by Bunyip02 on
    800 x 650 - 623K
    One more for the road....
    800 x 650 - 625K
  • If you render the buddha inside you can of course delete all the outside and fancy fake GI and just use 3 point lighting
    thanks.  this looks nice
    i had a thought to use it as a classroom scene.
    an eastern hogwarts
  • Guess I should post this in here as well, so someone will see it outside a seemingly completely dead thread.
    Don't know if using LuxCore is cheating or not, but these kinds of results are just straight up not possible in Carrara natively.
    Hi DragonSkyRunner
    Sorry for the late reply, I'm not sure how to enable notifications. Glad you found good use for the shaders, the car looks great.
    "but these kinds of results are just straight up not possible in Carrara natively."
    Hey Chris, thanks for stepping in and posting again.  You jogged my memory of your previous posts on realism - two years ago! - and I finally used the shader you so nicely provided.
    I am still relatively inexperienced with Carrara, and realism is a challenge for me (and these are early stages).  But I got pretty good results just by playing with your stuff.  Many thanks!
    another Howie render with World Gardens Japan with some slight adjustments with my models wink
    500 x 650 - 598K
    Post edited by Stezza on
  • chris poolechris poole Posts: 126
    Some Renders of some shaders. Some I haven't a clue what they are.... Goodness knows if I've attached these correctly..
    2560 x 624 - 525K
    2560 x 624 - 516K
    1280 x 853 - 220K
    2560 x 624 - 515K
    2560 x 1288 - 1M
    2560 x 1186 - 768K
    2560 x 1597 - 974K
    Post edited by chris poole on
  • Chris,
    I really like the ones in Doc7. Can you share the settings that you used to create them?
  • Chris,
    Sure thing, perhaps sharing the scene file if that's allowable and desireable? There is nothing in there but my shaders and primitives.
  • another Howie render with World Gardens Japan with some slight adjustments with my models wink
    Very nicely done! smiley
    yes Loo with a view !!
  • Tea is a duretic ...
  • DiomedeDiomede Posts: 15,463
    Another render quickie with stuff from my Runtime that I need to use more often.  Kitbashed a 50s scifi suit from the GCop helmet, cabana wear, and Jessica Rabbit gloves all for G2F.  Also the toon rocket, and some DAZ robots (JC....) and a Daz moonlander.  I put together the simple Carrara terrains, Carrara spheres for planets, and Carrara text.
    Just having some quick fun.  Also known as Vicky in a spacesuit with a robot.  VIASSWAR
    942 x 1600 - 912K
    Post edited by Diomede on
    What was that?  Did you say that RocketWoman's spacesuit is not practical?
    Yes, you are correct!!!!   VIASSWAR   laugh
    You've been reading those 1950's Sci-Fi comics havn't you ?
    523 x 484 - 609K
    SciFi pulp - perfect for that unexpected hour wait while traveling.
    1547 x 752 - 327K
    oops meant to post it in other thread.
    Post edited by Mistara on
    Hivewire's Lion works great in Carrara yes
    800 x 600 - 820K
    another secret lake
    https://images-wixmp-ed30a86b8c4ca887773594c2.wixmp.com/f/863472d1-174d-4f16-81f1-f8c7aec943f9/dc4laqx-f3f9dc58-f47e-4898-bd2c-95ae07adc69d.png/v1/fill/w_1280,h_720,q_80,strp/secret_lake_by_realmgal_dc4laqx-fullview.jpg?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJ1cm46YXBwOjdlMGQxODg5ODIyNjQzNzNhNWYwZDQxNWVhMGQyNmUwIiwiaXNzIjoidXJuOmFwcDo3ZTBkMTg4OTgyMjY0MzczYTVmMGQ0MTVlYTBkMjZlMCIsIm9iaiI6W1t7ImhlaWdodCI6Ijw9NzIwIiwicGF0aCI6IlwvZlwvODYzNDcyZDEtMTc0ZC00ZjE2LTgxZjEtZjhjN2FlYzk0M2Y5XC9kYzRsYXF4LWYzZjlkYzU4LWY0N2UtNDg5OC1iZDJjLTk1YWUwN2FkYzY5ZC5wbmciLCJ3aWR0aCI6Ijw9MTI4MCJ9XV0sImF1ZCI6WyJ1cm46c2VydmljZTppbWFnZS5vcGVyYXRpb25zIl19.eE_cXywUBaHVKFFmTVikGi5mLeF2jdbSklsjBX-4eDk
    owie's koi pond    (gardens Japan)
    Yule cottage  https://www.daz3d.com/yule-cottage
    replication
    steampunk tavern and Villa in Carrara
    HFS Races: Catfolks by DarioFish for genesis.
    https://www.daz3d.com/bloodmage ; with Carrara metal shaders
    Delphinia skin shaders and hdri preset https://www.daz3d.com/carraracters-delphinia
    edited October 2019
    dusting off an old animation project
    thinkin if i add widgets to the planes can make it do crazy ivans
    carrara native content
    music done with sony acid. sound effect sony sound effects library
    playing with the sky altitude
    Wow, Misty, these are really cool.  The jet sound transition to music very smooth.
    +1 on that.. nice work @Mystarra yes
    thanks smiley
    found it made more sense to move the sky altitude than move the planes and camera.
    Make that a +2 !!
    shroom house under hdri.
    couldnt remember where the attenuation setting was, thought i saw inverse square
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,655
    You mean gamma?
    attenuate usually means to reduce limit something like keyframes or morphs influences in DAZ studio morphloader, can't recall anything with that term in Carrara myself
    edited October 2019
    has something to do with fall off,
    In photography and stage lighting, the inverse-square law is used to determine the "fall off" or the difference in illumination on a subject as it moves closer to or further from the light source.
    https://en.wikipedia.org/wiki/Inverse-square_law
