bullet physics for DS 1, 2, 3, 4 PC/Win ... teaser
15791011
  • mCasualmCasual Posts: 4,607
    edited November 2013
    new version of the client and new version of the server ( engine ) was posted
    notable change, you have access to the type 2 hinge ( steer and roll ) parameters
    the limit angles, the linear limits the suspension springs
    manual will be updated tomorrow concerning those changes
    https://sites.google.com/site/mcasualsdazscripts3/mcjbulletservice01
    400 x 400 - 950K
    Post edited by mCasual on
    Oh that looks like fun {and much safer for Amy lol ...} :-)
    off-screen the road flattens and she can get back to the safety pf her star-actor accomodations
    800 x 533 - 63K
    how the Dakota prop was rigged for the test simulation
    the ground cube was a 10 m. x 10 m cube turned into a static body
    example of a type 2 hinge rig
    the blue cube named "car body" is a dynamic body with a mass of 800
    setting the mass is done in the Physics/Body" section of the parameters tab
    make sure the collision shape selected for those to be "btBoxShape"
    collision shape selection is done in the Physics/Body" section of the parameters tab
    the Dakota's body is parented to it
    the two Type 2 hinges may be parented to it ( else they are left behind during the simulation )
    the large red cylinders are dynamic bodies with a mass of 50
    they are named "front wheel" and "rear wheel"
    make sure the collision shape selected for those to be "btCylinderShape"
    the Dakota's wheels are parented to them
    the green cylinders are type 2 ( steer and roll ) hinges
    the green cylinder is also the steer axis ( axis 1 )
    the smaller red cylinder is the roll axis ( axis 2 )
    the roll axis must be a child node of the steer axis
    parenting can be performed in Daz Studio's Scene Panel ( or using my mcjParent script )
    the label of the roll axis must contain the word "roll"
    re-labeling can be performed in Daz Studio's Scene Panel
    in the parameters tab of the hinge nodes :
    the front hinge links "car body" to "front wheel"
    body__A = "car body"
    body__B = "front wheel"
    the rear hinge links "car body" to "rear wheel"
    body__B = "rearwheel"
    the hinge spring parameters ( which may not be ideal ) were
    spring: On
    stiffness : 1.0
    damping: 0.01
    angular limits: -1 degree to 1 degree
    linear limits: -10 cm to 10 cm
    1930 x 1085 - 273K
    note that this poser/daz compatible low-poly Dakota prop
    with functional wheels, openable doors , and leather seats
    can be yours for free right over here
    https://sites.google.com/site/mcasualsdazscripts2/mcjdakota
    900 x 900 - 59K
    understanding the linear limits of the hinges
    apparently the springs on the hinges are always on
    this will be fixed in the next version
    so for now you could leave the limits at -0.001 and 0.001 to get the equivalent of a disabled spring
    in the figure 1 animation
    linear lower limit 0
    linear upper limit: 1
    spring off
    presently "spring off" means the physics' engine default settings are used
    probably stiffness is 0.0 and damping is 1.0
    to give you an idea of the sizes, the diameter of the yellow cylinder is 1 meter
    we get a spring compression of 1 meter
    in figure 2 you can see a plot of the position of the cyan cube ( the first body attached to the hinge )
    using a linear-lower-limit below 0.0 gives us a behavior that is hard ( for me ) to figure
    but using linear lower lower limit = 0 and linear upper limit = positive works well
    my conclusion is that the limits should be called
    minimum spring compression and maximum spring compression
    indeed if you look at the case where linear lower limit = 0.2
    the simulator forced a compression of the spring at frame 1
    1748 x 816 - 106K
    480 x 480 - 267K
    constraint-hinge parameters take some trial and error work
    often it seems the constraints are fighting one against the other
    one way to solve this seems to make the body of the car much heavier than the wheels
    in the example below wheel mass = 4 car body mass = 400
    hinge parameters
    linear upper limit 0.1 ( 10 cm )
    spring On
    stiffness 50
    damping 0.001
    512 x 288 - 237K
    in a previous test increasing the ground cube thickness helped
    in this case increasing the wheel widths helped
    512 x 288 - 295K
    maybe locking wheels and bizarre speed profiles are due to friction properties of the wheels
    so next i'll look into adding access to that
    512 x 288 - 450K
    647 x 803 - 68K
    see see ?
    a motor
    so that's nice, we'll have motors
    though i have to fix the hinge which is has an offset on it joint location
    in case anyone is following this and trying out type A hinges
    the physics engine works better if your physical bodies have their Origin at the center of mass of the body
    to change the location of the Origin, i use the MoveOrigin script by DeltaX15
    ( which is quite an essential tool if you create complex props in Daz Studio )
    Primary Download Link http://www.4shared.com/dir/722776/10801f63/DS_Scripts.html
    Alernative Download Link 1 http://www.savefile.com/files/112075
    Alternative Download Link 2 http://www.badongo.com/file/1468225
    figure 3 shows the way the "angular motor" in Bullet Physics behave
    i often read that bullet physics is meant for games and not for precise realistic simulations
    and i think the motors are an example of that
    i read elsewhere that those motors are also weak !
    it's odd ( and possibly not true ), but some people were trying to
    build machines with motors and the motors were too weak to lift heavy objects
    using the parameters
    enableAngularMotor, (, bool, enableMotor,. btScalar, targetVelocity,. btScalar, maxMotorImpulse. )
    hingeConstraint->enableAngularMotor( true, 3.1416*3, 10 );
    we obtained an angular speed of 3/2 turns per second
    3 pi is 1.5 times 360 degrees expressed in radians ... so we understand targetVelocity
    846 x 797 - 98K
    512 x 512 - 240K
    a fancy fast car !
    ( angular motor for type 2 ( steer and roll ) hinges
    512 x 512 - 523K
  • RAMWolffRAMWolff Posts: 10,369
    Your such a code genius. I don't understand a bit of it but I like the fun animations
    Oh! The makings for a car right out of Bedrock :-)
    fluke object ( called it heavenly star ) while generating icosahedrons from dodecahedrons
    fig 2 is the intended result
    1000 x 1000 - 476K
    512 x 512 - 786K
    PURTY!
  • sjfryer_a638239a69sjfryer_a638239a69 Posts: 19
    The three princes would be proud of you!
    yes yes i will get back to the physics simulator :)
    927 x 1200 - 216K
    Whoa! That's kool! Aren't flukes fun ;-)
    tomorrow i'll most likely post version 02 of the physics simulation kit
    with always-on or always off motors
    eventually the motors will be animatable
    and down the road i didnt say it but there may be a "real time" interactive mode
    of course it all depends if i dont get caught in making cars for Amy
    1800 x 1012 - 332K
    927 x 1200 - 193K
    Love the VW! Love that car!
    i'll probably put it on mys site for free ... before xmas hopefully :)
    it now has an interior lining and open'able doors and the windshields are almost there
    1440 x 810 - 192K
    1920 x 1080 - 408K
    WOW... that's really awesome!
  • atticanneatticanne Posts: 3,009
    Where's old Santa Claus? I want to sit on his lap and tell him to put one of these in my driveway Christmas morning.
  • edited December 1969
    Cool car!!!!
    (... I hope it will have moveable pedals ;) )
    edited December 2013
    tightened ( and will have to un-tighten the fit of the doors
    finalized the flat rounded cornered windshields
    improved the VW crest
    added door hinges
    improved the V/nose thing :)
    it will be a multi-part prop so ... likely all the hinged things will be animatable including simple pedals
    1920 x 1080 - 361K
    Your so pretty and witty and VEeeWyullllle
    Part of me wants to say Hurry Hurry; the other part says Take your time and get it right. Thank goodness you're the one doing this so it's your call.
    the rear of the cab now correctly attached to the uh pickup bed
    the side windows
    the quick n dirty hubcaps
    1280 x 720 - 214K
    1280 x 720 - 158K
    Looks fabulous!
    now addressing the issue of inclined door hinge axis oh my
    not to mention the fact that nobody knows what's the plural of axis
    875 x 198 - 28K
    1920 x 951 - 180K
