effects tab issue
VIArts
Anyone else et a lagginess when you go into the effects tab of a figure? Speeds up when i manage to get out of that tab
VIArts
a figure in particular?
Always lags on hair effects
Wow, i wasn't notified of responses...
it's laggy with any figure,.
i'll try yoinking pluggies
Open Carrara.
Load a figure.
Select "Actor".
Go to Effects tab. Do sojmethng, like simply enable Aura or collapse a section.
Lag! Close Carrara.
Delete one plugin.
Repeat entire process.
I deleted the only added plugins in my effects tab -- Cognito, Wireframe pro, Toon pro -- without reinstalling them. No luck
I actually doubt it's the plugins, it's always done it for me, just one of those things
I just did a fresh reistall and that didn't help ether, so...
it could be the scene preview which is the lag after changing effects
try lowering the settings in ipr, like, turn off transparency,
try change the texturing from full texturtes to the ball to the left of it.
in the whatnow? lol
very strange.. I haven't had any issues at all with this problem... so I'm no help
fun!
i never went into edit blur before
interactive shader setting can affect speed of preview window.
interactive settings will affect preview speed. doesn't affect the render, just the preview window
I just started having an issue with lag each time I open the UV mapper in the Vertex Modeller. Have only been able to solve it by switching the interactive renderer from OpenGL to software or vice versa. It doesn't matter what I switch to, or if I switch back right away, just that I make a switch. Never had that issue before this week.
P
did your video driver update?
Misty, how do i rfind that interactve render dialog?
Hi
theres a hard to see red arrow pointing to the icon top right of preview window, it's an up arrow
MAJourney, if you are colourblind for the colour red let us know and someone will redo the red bits in a different colour.
it was hard to see against the background but i see it. thanks misty and bunyip
well, that didnt work either
