DAZ studio is unable to find Crimson Court [SOLVED]
SylvanSylvan Posts: 2,719
edited November 2013 in The Commons
Somehow DAZ is unable to find Crimson Court.
I tried installing it with DIM and by hand but no difference so far.
Also I checked if the content manager is started and it is.
Manually adding it with the content directory manager won't work either, neither did import metadata help. :(
I tried other items but no problems with others I could find...
See the picture for the error message...it's odd because everything works fine and I am out of ideas...
Post edited by Sylvan on
    I have Crimson Throneroom, but not the Court.
    It is a .DAZ scene file, so it is almost certainly looking for items from the 'data' folder from whatever library you installed it into. I loaded the Throne Room OK, but I installed it into My DAZ 3D Library from the beginning using DIM.
    In the data folder, there is a 'LaurieS' folder which has a folder called 'LS_CK2', that may be it. Do you have a LaurieS folder in your data folder?
  • SylvanSylvan Posts: 2,719
    Yup, it's all there.
    But I am starting to think it's a corrupted database because my search function won't work either anymore :(
    Last time that happened was a year ago ><</p>
  • RuphussRuphuss Posts: 2,631
    you have the crimson throne room ?
    its required
    Post edited by Ruphuss on
    its required
    I feel realy stupid...I purchased the throne room and it works now!
    Thanks you so much!!!
    Well spotted ruphuss!
    @Estroyer
    Don't worry about, we've all done it.
    yes like me with quel bazar
