Content installs into My Daz Library but....
Content, say from Renerosity or other third party vender installs into My Daz Library and can be found in the in the Daz Library through opening the Content tab. This used to work fine. However in my last two installs, the main product folder shows up, but no content icons are seen, in the main or any of its subfolders. Now if I do a "browse for file location" from the main folder and double click on the on the .duf I want, which is right where it should be, another copy of Daz opens and the item loads to the viewport and I can use the model as usual. This has now happened to two files I installed today, from different vendors and both from makers I have intalled items from before. So... any thoughts, did I click a button I shouldn't have, hallowen is approaching, I didn't finish my brocolli? And of course I have now spent a couple hours trying diff. things. Any thoughts greatly appreciated.   Pic 1 shows what I am talking about and pic 2 diff product, how it should be.
  • barbultbarbult Posts: 27,511
    The Dungeon has an arrowhead next to the folder name, indicating that it has subfolders. You probably need to look in those subfolders.
