Object as light source
riccoptriccopt Posts: 0
edited November 2013 in Daz Studio Discussion
is it possible to have an object (for example a cube) and make it emit light that will cast shadows without adding and extra light?
from what I have tested using ambient wont do it.
Post edited by riccopt on
  • CyberDogCyberDog Posts: 232
    I am not sure if this is what you are looking for. I applied uberarea light base to the cube and turned off the ambiance. If you turn phantom on the cube will be invisible. The only lighting in these images comes a distant light with shadows off.
    500 x 500 - 33K
    500 x 500 - 28K
    Post edited by CyberDog on
  • JaderailJaderail Posts: 0
    Cube, Uber Area light Base Applied. Intensity set to 200% samples set to 32. All lighting is FROM the cube.
    500 x 500 - 66K
    Post edited by Jaderail on
  • riccoptriccopt Posts: 0
    I want something like that... I have been playing with the uberlight now... hopefully I will get the desired effect...
    seems like I will have to play with those setting now... and that in a few more days I get to do exactly what I want...
  • FirstBastionFirstBastion Posts: 8,048
    The reality plugin for DAZStudio also gives the option to set any mesh object in a scene as a light. The cube is the light, and depending on its relative size the shadows are softer or harder based on physics.
    650 x 650 - 349K
    650 x 650 - 300K
  • ben98120000ben98120000 Posts: 469
    Link to Szarks tutorial:
    Tutorial Uber Area Lighting: The Basics
  • SzarkSzark Posts: 10,634
    One aspect I forgot to include in my tutorial, thank you for that. I will add this when I update it soon.
    Thanks Ben, saved me doing it. :)
