Genesis 8 male problem
Any help would be greatfully accepted, when i load a genesis chatacter it loads a muscle bound genesis 8 male base. No matter what genesis character i choose.the same figure loads every time.
  • SimonJMSimonJM Posts: 6,100
    edited September 2019
    Sounds like some morphs (for another figure,likely from a 3rd party source) are set with a default value of 1, meaning they will affact any G8M figure l'd suggest making sure show hidden parametrs is set in your Parametrs tab, then go looking to see what is set.  Using the show currently used option may help, but I seem to recall these don't always show up there as they are deemed to be a default (i.e., unchanged and unused as they are set at figure load).
    Post edited by SimonJM on
  • 3Ddreamer3Ddreamer Posts: 1,357
    Do you have Alistair installed? He was doing that at the start, but he has been updated - if you have him, uninstall, and download the latest version. and see if that fixes all your G8M men.
  • Thanks for the info uninstalling Alistair cured the problem.
    Redownload from your account and reinstall, that will get the fixed version.
