G8 Eyes not Closed even with parameter at fullest
I'm short of ideas...and binary, it that parameter says Eyes Closed, then, I Would like THAT eyes closed, but not doing the job, someone got or found a way to fix that?
  • Looks like there's a morph applied to the head which lacks an MCM for the eyes closed. Have you used OBJ Export/moprh import to bake several shapes into one?
  • nicsttnicstt Posts: 11,715
    edited September 2019
    Have a look through your morphs; some PAs have included a custom eye closer, and it can work with other characters.
    You could also try turning off limits and then dialling the eye closed more than 100%, which may or may not turn out well. :)
    Your best option though, might be to follow Cris's suggestion.
    Post edited by nicstt on
  • Looks like your eye shape is not compatible with the existing morph.
    A probably satisfactory fix without making making own morphs would be to own Emma&Jordis Face Morphs which has 3 morphs Eyelids lower height for inner, middle and outer.  (Maybe Rarestones face moprhs would work too).  The you adjust the the inner and outer and leave the middle (or adjust it way less than the other two).
    Adjust as needed then save that moprh preset as a one click duf.
    she is Tika8 at X% only, no other morphs on the face is applied.
  • ZilvergrafixZilvergrafix Posts: 1,385
    link of that product?
    Post edited by Zilvergrafix on
    Yep. that fixes at some percent, turning off limits AND playing with eyelashes moving below than normal creates a solution I was looking for.
    THANKS ALL FOR YOUR SUGGESTIONS! cool
    803 x 847 - 890K
