RSSY Clothing/Character Converter G3F to G8F can't find selected items.
Greetings. I have purchased the G3F to G8F clothing converter in the hope that it helps me to deal with some issues I have with AutoFit and manual figure space transfer.
I want to convert the nurse uniform by ironman13. And I got the message that no item is selected, but, well, it is.
See attachment.
I ran into a similar issue with another RSSY script, the character converter, since I have installed the Centaur for Genesis 8. The character Makemba can't be converted due to the same problem.
    edited August 2019
    The check mark isn't "selected". They must be highlighted in yellow. Click or shift click on the desired range.
    Post edited by fastbike1 on
  • HighElfHighElf Posts: 373
    Did I miss additional checkmarks? In the pictures, the items are selected. The list also says that they are checked. frown
  • Gusf1Gusf1 Posts: 258
       It looks like you selected "execute from selected" not "convert items"
                                   Gus
    Yeah, I've done that, to show the issue. Whit the plain execution, the tool just said that it runs and finishes with 0 clothes converted.
  • carrie58carrie58 Posts: 4,151
    edited September 2019
    Try not just using the check mark but click on the item  to hylight it then try force convert ,and just a FYI the character converter will not work on the Centaur because it is a geograft character .....
    Also if you are still having issues check in the commercial thread RSSY is really great about helping out with any problems people are having with their products
    Post edited by carrie58 on
