model disappears when seen from bottom
When I bring my model into the render or other pane & look at her from below she disappears. Or when I see her from the perspective pane and tilt to down below the floor. Tried a lot of things but so far have not hit the right option or collection of options.
  • FishtalesFishtales Posts: 6,228
    If the camera is below the floor it wont see the model. Turn Draw Ground off and it should show up.
    I was going to say she's probably shy, but @Fishtales advice is much more helpful!
  • marblemarble Posts: 7,500
    Maybe should add that the ground on/off switch is in the Render Settings pane > Environment > Draw Ground (just in case).
  • Thanks, Fishtales. Worked. To be specific, for anyone unclear on exactly how to do that, I went to Render tab > Render Settings > Environment > Draw Ground > Off.
